Just noticed this has popped up
I built this mixer and got stuck:
sound getâs trough but is barely noticeable
the switches and potentiometers work
doubleckecked my (sloppy) soldering and swapped some parts (R1, R2, C5, C6, TL072cp)
this might be related to mixer cutting freq
i take to power from my fartbox
when i unplug power i hear something at normal volume while the capacitors inside are draining
the BOM sais âanyâ capacitor or resistor at multiple places maybe i went wrong there?
Hey, is the fartbox still working when the mixer is plugged on the same power supply ?
It could be that you do not get the +/12V supplied properly. I have this problem sometimes. Only the neg rail is being supplied. The sound you can hear could be just âpassiveâ (no amplification). When you unplug, the power might send a short +12V to the opamp and give you a second of signal
My view is that the capacitors are not absolutely needed to get this mixer to work. It is much better with it but it would work without it.
If you can, check the opamp has got the +12-12V supplied on the correct pin (4 and 8) and you can also check continuity, this circuit is tiny so it shouldnât take too long.
Good luck !
you cant go far wrong with it, have you checked the poer rails at the opamp?
I think the mixer is (mostly) fine. I killed the fbox i used as power supply. if you like drama you can follow my progress in the fbox thread. to keep it short and on topic: iâll report back when i have my basics sorted ![]()
thx for your support and encouragement
Not too sure what you mean by using the FB as a power supply
Do you mean youâre taking the +/- 12V/ground connections from the fartbox? How is that being supplied?
By âany resistorâ, I think the BOM means the type of resistor (metal film, carbon film, wirewound, etc), not the value (measured in ohms - 500k, 100r, 2M, etc). Have you used the values from the âDesignationâ column?
Totally OT side note: would it work to have a seperate category for all the âofficialâ module topics? I often find myself having to search for them, and they arenât all titled the same way which means it becomes quite cumbersome to find them after a while.
Does this help?
I donât know how I forgot about that. It only appears pinned when I log out, but that might just be my profile settings. Thanks! Bookmarked for future reference.
- @Bpbby was right. pin 8 was missing itâs 12v
- circumvented any power proplems i might have had by adding a âpaid & prebuiltâ power supply
- now itâs working (demo clip)
Having similar problems, no sound coming out.
Pin 8 seems to be connected to ground, c3 and +12v donât seem to be connected to pin 8 or ground. Not sure how this is happening
- using b100k pots
- using on/off switches with no third pin
- is the power connector at the bottom? input 1 is at the top on the front panel but input 1 is at the bottom near the output on the back. I plugged 1 into 6, 2 into 5 etc. and output into output
- checked plugging in input one and adjusting input 6
is the TLO72 and power header oriented correctly. Thereâs nothing else that can really go wrong, but if your not getting the correct voltages at the OP AMP nothing is going to work,
Yup the notchâs is pointing away from the power socket.
I removed the chip and header to see if pin 8 still connects to ground and it does
Looking closely, surely Iâm seeing this wrong but pin 8 shouldnât connect to pin 3 over the large area right? (pin 3 should connect to ground though, which it does)
You appear to have drawn a line between pins 3 and 5, not 3 and 8.
OMG thanks so much, i knew i must have been thinking about it wrong somehow but i couldnât see it
Just want to confirm two things
- is it ok to use two pin switches leaving the third pin on the board empty?
- having input 1 on the face plate connect to 6, 2 to 5 etc.?
It is OK⌠IF you have put them in in the right orientationâŚ
Unfortunately I donât own that module so I canât confirm if your orientation is the correct one.
Try shorting with a wire the middle pin and the non-connected pad of one switch and see if it worksâŚ
Two pin switches are fine and your orientation is correct.
The inputs are all identical except in name, so having the legends reversed between PCB/FP has no effect.
Are you getting +12 and -12V on the correct pins on the OP-AMP.
Hello,
I was breadboarding this module from the schematic and I have an issue. Every time i add an input volume it adds to the output voltage and so it outputs 5v with a single input, 10v with 2 inputs âŚ
What iâm doing wrong?
Sounds like nothing wrong, if I understand your question. A mixer adds its inputs. Of course you canât get much more than 10 V out of the op amp, so with a third input, if all of them are 5 V, the output will be clipped. Assuming you donât want clipping, you then have to back down on the three (or four, five, or six) attenuator pots. I like mixers that have a variable resistor in the first stage feedback for that reason, you can just decrease the gain on that stage instead of having to fiddle with all the input pots.
