All Chats about this filter. maybe a mouser cart. or places people have found stuff for it.
chat about it here!
Im updating the filter panel relatively soon it was the first module I put out, for instance the mounting holes were made for wood screws only! instead of for both rails and wood rails like the others, however like me I can imagine most people building this are going down the wooden rails route!!! its the best!
I was wondering why you said you’d be putting out a new design when you sell off existing stock. If it’s just about the holes, I may buy one of the old boards because I think I can probably live with odd holes. I haven’t yet worked out how I’ll adapt heterogeneous module sizes, but it will probably involve custom-built sabots prototyped in 2mm backing card (“brownboard”) and then (if necessary) built in plywood.
I want to make all the mistakes, so others don’t have to. Maybe 2mm card will be incredibly durable, cuttable and drillable. Maybe wood merchants will take pity on the weird guy and give me free offcuts.
hahaha yeah to be honest its not a problem, I can imagine most people will be using wooden rails. and to be honest the holes are actually fine for metal rails. however they are a tad larger than M3 thats all. it would actually still work!!! haha cool! let me know how it goes
That’s what I thought but my brain would not except having it in the wrong way. Now my brain has to except that I turned into a honey badger getting it out, thanks fredrik.
Get some flux, solder wick and don’t turn the temperature up too high. If a hole just won’t clean up, add solder, then try removing it. If all else fails, do some very careful drilling.
I second what fredrik says!!! all good I do it loads!!! just remember. sometimes I put a sharpie on it if its a mistake. its fine though you’ll sort it! just got to get that solder out somehow!
I finally looked at that video and for $5 shipped from Kentucky I had to have them. Why is the memory of components getting stuck to the side of a through-hole so when desoldering so much more vivid than the memory of what the component or even the project was?
I just noticed that the output of the filter is very low in loudness( is that the word)? I mean the incoming signal is a lot louder than what comes out of the filter, even if it does not really filter… is this expected or have I made some mistake?
Mine is the same, but only in low pass mode. In high pass mode it seems fine. Observed behaviour in mine so far is that in low pass with the cutoff all the way open it’s about half as loud as in high pass mode with the cutoff all the way open (opposite direction than in low pass). I have the trimpot all the way clockwise.
Oh I’m a total noob too bro I just happened to know that about the VCO, probably read what @fredrik said before. That being said my high pass is much louder than the low. I think it’s normal?
Humans have non-linear interpretations of loudness contours. We evolved to favor specific frequencies between 2 and 5 kHz due to the resonance of the ear canal and the shape of ear bones (Ossicles).
