Right! its on its way, I figured id make the thread! this module took a bit of teething, so I’m sorry for the wait but surprisingly still keeping to a module a month!!! give or take a week here and there.
I’m putting together the documentation and videos etc for it today/tomorrow.
everything including the listing should be up on Friday. fingers crossed!!
it comes with the CV12 chip with slightly modified code including return to bass characteristics, defaulting on the mode 4 channel Mono, and also C as 0v (the standard actually has A as 0v), I bought a bulk from Midimuso and will include with the listing, and also it comes with the 2 4504’s as it was pointed out to me that they need to be Texas instrument ones, as other manufacturers 4504’s showed slightly erratic behaviour. so to save some head scratching I got a whole bunch of them too.
ahh super.
I think this will be an enabler for a lot of us that may have a suitable keyboard :slight_smile:
(or more likely, the design depends on undefined behaviour (I mean, we’ve already seen the rather creative use of a non-regulating LM317 in the original muso :smiley:))
EDIT: Wait, the reference schematics use MC14504, but that’s not a Texas component? Confused.
Thank the gods… this has been hanging on my wall for a while now :stuck_out_tongue:
I’m totally going to use my old ass Miracle Piano Keyboard lol…
Just need to disable its onboard speaker…
Oh we had one of those when genius son was a little boy. Had to give it away when we moved back from London.
yes sorry fredrik that schematic had the wrong component designation.
but yes that’s is also very true! I mean it doesn’t seem to. and to be honest I have not tried it with other brands and I may very well do so!± infact im going to order some and see what happens.
I may aswell see what midimuso is on about. before I question the voodoo gods!±!!
a classic! the miracle piano ha
It’s up! https://store.lookmumnocomputer.com/collections/all/products/1007-midimuso-midi-cv-module-pcb-panel-chipset
Was all set to order a third VCO too, but it’s back ordered.
I’ll start a Tayda list
Yeah. I got the last one I think. For now. I hope more are on the way. The same for the mixer.
aaah sorry on the VCO’s! they are back next week! I hadn’t realised until a bit too late on those ones!!
Im pulling together a video on the midi module at the minute, it shouldd be up on Sunday, running through the build and calibration etc.
I think this covers it
https://www.taydaelectronics.com/tl431acl-tl431-precision-shunt-regulator.html
https://www.taydaelectronics.com/40-pin-2-54-mm-single-row-pin-header-strip.html
https://www.taydaelectronics.com/10-pin-box-header-connector-2-54mm.html
https://www.taydaelectronics.com/10uf-25v-105c-radial-electrolytic-capacitor-5x11mm.html
https://www.taydaelectronics.com/a-553-0-1uf-50v-ceramic-disc-capacitor-pkg-of-10.html
https://www.taydaelectronics.com/10-x-22pf-50v-ceramic-disc-capacitor-pkg-of-10.html
https://www.taydaelectronics.com/0-01uf-50v-80-20-ceramic-disc-capacitor.html
https://www.taydaelectronics.com/1uf-50v-radial-tantalum-capacitor.html
https://www.taydaelectronics.com/1n4148-switching-signal-diode.html
https://www.taydaelectronics.com/connectors-sockets/wafer-housing-crimp-terminal/serie-2500-2-54mm/wafer-connector-2-54mm-3-pins.html
https://www.taydaelectronics.com/connectors-sockets/wafer-housing-crimp-terminal/serie-2500-2-54mm/housing-connector-2-54mm-3-pins.html
https://www.taydaelectronics.com/connectors-sockets/wafer-housing-crimp-terminal/serie-2500-2-54mm/wafer-connector-2-54mm-2-pins.html
https://www.taydaelectronics.com/connectors-sockets/wafer-housing-crimp-terminal/serie-2500-2-54mm/housing-connector-2-54mm-2-pins.html
https://www.taydaelectronics.com/connectors-sockets/wafer-housing-crimp-terminal/serie-2500-2-54mm/crimp-terminal-connector-2-54mm.html
https://www.taydaelectronics.com/resistor-10-ohm-1-4w-1-metal-film-pkg-of-10.html
https://www.taydaelectronics.com/resistor-5-1k-ohm-1-4w-1-metal-film-pkg-of-10.html
https://www.taydaelectronics.com/resistor-220-ohm-1-4w-1-metal-film-pkg-of-10.html
https://www.taydaelectronics.com/10-x-resistor-100k-ohm-1-4w-1-metal-film-pkg-of-10.html
https://www.taydaelectronics.com/10-x-resistor-10k-ohm-1-4w-1-metal-film-pkg-of-10.html
https://www.taydaelectronics.com/10-x-resistor-1k-ohm-1-4w-1-metal-film-pkg-of-10.html
https://www.taydaelectronics.com/10-x-resistor-270-ohm-1-4w-1-metal-film-pkg-of-10.html
https://www.taydaelectronics.com/14-pin-dip-ic-socket-adaptor-solder-type.html
https://www.taydaelectronics.com/16-pin-dip-ic-socket-adaptor-solder-type.html
https://www.taydaelectronics.com/6n137-high-speed-logic-gate-optocouples-ic.html
https://www.taydaelectronics.com/tl074-quad-operational-amplifier-j-fet-pdip-14-tl074cn.html
could not find this on Tayda
alternate:
https://www.taydaelectronics.com/74hc14-7414-ic-hex-schmitt-inverter-high-speed-cmos-ttl.html
https://www.taydaelectronics.com/16-000-mhz-16-mhz-crystal-hc-49-s-low-profile.html
https://www.taydaelectronics.com/l78l05acz-l78l05-78l05-5-volts-100ma-voltage-regulator-ic.html
https://www.taydaelectronics.com/5k-ohm-trimmer-potentiometer-cermet-25-turns-3296w.html
https://www.taydaelectronics.com/10k-ohm-trimmer-potentiometer-cermet-25-turns-3296w.html
https://www.taydaelectronics.com/brass-standoff-spacer-screw-hex-male-m3x10mm-silver.html
https://www.taydaelectronics.com/nut-3mm-for-screw-m3.html
https://www.taydaelectronics.com/phillips-round-head-screw-m3-0-5mm-heat-sink-to-220-to-247-transistor.html
https://www.taydaelectronics.com/8-pin-2-54-mm-single-row-female-pin-header.html
https://www.taydaelectronics.com/2n3904-npn-general-propose-transistor.html
https://www.taydaelectronics.com/6-35mm-1-4-stereo-phone-jack.html
https://www.taydaelectronics.com/leds/round-leds/5mm-leds/red/led-5mm-red.html
https://www.taydaelectronics.com/resistor-100-ohm-1-4w-1-metal-film-pkg-of-10.html
https://www.taydaelectronics.com/tl072-low-noise-j-fet-dual-op-amp-ic.html
https://www.taydaelectronics.com/8-pin-dip-ic-socket-adaptor-solder-type.html
Tayda does not have the midi sockets, alternative:
or
Order is in :slight_smile:
I need to take stock of my build and testing progress. I have forgotten what modules are tested and fully working.
The 74HC14 should do just fine as it is capable of ±4mA and this circuit won’t use more than about 1mA.
I was hoping someone would chime in with that useful information
Thanks
thanks Antoine! the all seeing eye!!!
The 74HC14 is fine for driving the MIDI THRU outputs.
Surprisingly it might be a bit marginal for driving the LED’s transistor, which pulls about (5-0.7)/1k = 4.3mA, but the 74HC14 is still better than the 74LS14 which is only rated for 0.4mA for a high output.
I would just replace that 1k resistor by 1.2K to be on the safe side. Shouldn’t affect the LED’s brightness significantly.
EDIT: I was going off the Texas Instrument data sheet, according to Tayda’s web page, the 74HC14 can drive ±5.2mA so it’s OK as-is with the 1K resistor. The 74LS14 on the other hand could use a 12K resistor… which would still probably give a plenty bright LED as the transistor would still be saturated.
