Layout credit: LMNC (Sam Battle)
Transcription of instructions:
- CGS dc mixer in its simplest form basically. I use this circuit in many things. Including the bruel and kjaer fixed filter bank, who’s video I made this strip-board layout for.
- Remember if you are using a plastic panel, make sure to ground all jack sockets
- Potentiometers are facing up.
- Pin 2 of the TL072 is where all the inputs go into, you can actually have as many inputs as you want (in the bruel and kjaer fixed filter bank video i have 30!). To add more inputs is very simple. Put another 100k resistor to pin 2 of the TL072 and then copy the input jack and socket stuff and BOOM, you have as many inputs as you require.
- You can make this go to a lot more complicated town, adding inverting switches etc, but this is mainly for audio so inverting the signal isn’t too useful. A strip-board layout for a mixer aimed at control voltages will come.
Layout:
Bill of Materials:
SMALL STRIPBOARD 93X55MM (COPPER)
https://www.taydaelectronics.com/small-stripboard-93x55mm-copper.html
$0.66 / £0.50
Quantity: 1
TL072 LOW NOISE J-FET DUAL OP-AMP IC
https://www.taydaelectronics.com/tl072-low-noise-j-fet-dual-op-amp-ic.html
$0.34 / £0.26
Quantity: 1
1K OHM 1/4W 1% METAL FILM RESISTOR ROYAL OHM TOP QUALITY
https://www.taydaelectronics.com/10-x-resistor-100k-ohm-1-4w-1-metal-film-pkg-of-10.html
$0.012 / £0.0092
Quantity: 1
100K OHM 1/4W 1% METAL FILM RESISTOR ROYAL OHM TOP QUALITY
$0.012 / £0.0092
Quantity: 6
Total Price: $0.072 / £0.055
6.35MM 1/4" STEREO PHONE JACK
https://www.taydaelectronics.com/6-35mm-1-4-stereo-phone-jack.html
$0.45 / £0.35
Quantity: 4
Total Price: $1.8 / £1.37
100K OHM LINEAR TAPER POTENTIOMETER SOLDER LUGS ROUND SHAFT DIA: 6.35MM
https://www.taydaelectronics.com/b100k-ohm-linear-taper-potentiometer-round-shaft-solder-lugs-l.html
$0.50 / £0.38
Quantity: 3
Total Price: $1.5 / £1.14
AWG 22 BLACK HOOK-UP WIRE 1FT (30CM) SOLID
https://www.taydaelectronics.com/awg-22-black-hook-up-wire-1ft-30cm-solid.html
$0.10 / £0.076
Quantity: 5
Total Price: $0.50 / £0.38
AWG 22 BLUE HOOK-UP WIRE 1FT (30CM) SOLID
https://www.taydaelectronics.com/awg-22-blue-hook-up-wire-1ft-30cm-solid.html
$0.10 / £0.076
Quantity: 1
AWG 22 RED HOOK-UP WIRE 1FT (30CM) SOLID
https://www.taydaelectronics.com/awg-22-red-hook-up-wire-1ft-30cm-solid.html
$0.10 / £0.076
Quantity: 1
AWG 22 GREEN HOOK-UP WIRE 1FT (30CM) SOLID
https://www.taydaelectronics.com/awg-22-green-hook-up-wire-1ft-30cm-solid.html
$0.10 / £0.076
Quantity: 1
AWG 22 YELLOW HOOK-UP WIRE 1FT (30CM) SOLID
https://www.taydaelectronics.com/awg-22-yellow-hook-up-wire-1ft-30cm-solid.html
$0.10 / £0.076
Quantity: 5
(unless you can connect them via wires). I’d also add, say, a 330 ohm current limiting resistor on the output to get a bit more protection.
