Eurorack Synth Noodle Toaster v2
The move from passive mixing and filtering, to active mixing and filtering, means I suddenly needed a PSU that could also supply a negative voltage rail. Rather than just buying a Frequency Central power unit and getting on with my life, I decided to buy a Eurorack Synth Noodle Toaster v2 PCB, and pre-flashed chip, from amazingsynth.com. I realised that I as I’m only starting out, a way of generating various signals, gates and counting frequencies, might prove useful, in addition to being able to provide +/-12v.
I intend to document my progress here, just in case anyone else decides to build one of these things.
In an unusual fit of KISS, I decided that I would just buy the contents of the Mouser BoM that is linked further down the amazingsynth.com page. With that in mind, it seemed prudent to buy both the tactile switches and LCD module at the same time as the PCB and chip. While waiting for everything to arrive though, I decided it would be prudent to at least price up buying all the components from a UK supplier, so I started a spreadsheet.
It wasn’t long before I started to have doubts about the accuracy of the Mouser BoM. I’m not overly experienced with electronic componentry, but I can look at a data sheet and work out from the product ID what the pin orientation should be etc. It seemed odd that certain components, like the trim pots, seemed to be listed with product IDs that had incorrect pin layouts.
For example, according to the data sheet, the Bourns 3386U-1-502ALF has all three pins in a straight line. All the photos of the PCB I could find online though, made it look like that trim pot needed the pins in a triangle layout, i.e. a 3386P. My concerned were further raised when I looked at the original BoM linked to from the Mutable Instruments website, and it listed a 3386P.
This was enough for me to ditch any idea of buying the Mouser BoM, so I went through each component on it and found what I though were the correct variants, or similar alternatives. This would’ve been easier if I could’ve found any super clear photos of the PCB online. There are a few but mostly with missing component information, the vast majority are of the older v1 board, so I couldn’t rely on those, just in case.
My PCB arrived the other day, so here are scans of both sides, so you can clearly see what components are supposed to go where and what their pin layout should be.
Front:
Back:
The first step to creating my own BoM for this project, was to convert the Mouser BoM. I found it very confusing that all the components were mixed up and that they didn’t have identifiers for where they were on the board. I thought that someone must have documented building one of these things, or made a video, or something. Either my google fu is weak, or pretty much nobody has bothered.
I think there was some confusion, not helped by the amazingsynth.com website, about what this thing is actually called. Is it a Module Tester, or a Noodle Toaster…? You’d think if it was Noodle Toaster, the big page title on your website might read New Noodle Toaster v2 PCB and pre-flashed chip set. :man_shrugging:
Anyway, searching for Noodle Toaster, rather than Module Tester, eventually turned up a couple of recorded livestreams of someone trying to build it. I wouldn’t say it made for riveting viewing, but it was reassuring watching someone who appears to have way more knowledge and skill than me, struggle to figure out what was going on.
It further highlighted the fact that the Mouser BoM is a load of bollocks and should be avoided at all costs contained a load of inaccurate components. The other thing it highlighted, was that I could probably get an accurate list of components from the original schema files that are on GitHub. They wont load in KiCad though, but thankfully @analogoutput has cloned the original repo and converted the files to they can be loaded by KiCad.
Armed with a freshly exported bill of materials, it was simply a case of going back through each component and trying to ensure I had the correct amount of the correct thing. I’m not 100% sure I’ve got everything correct, so do your own research and take the following table with a pinch of salt:
Component ID Description Quantity Rapid Farnell
R14 Wire bridge, or 0R resistor 1 62-0650
R19, R20, R21, R22, R3, R23, R25, R27, R24 220R Metal film resistor, 1%, 0.25W 9 62-3434 9341528
R1, R2, R34, R35 470R Metal film resistor, 1%, 0.25W 4 62-3442 9341943
R26, R5, R17, R6 10K Metal film resistor, 1%, 0.25W 4 62-3474 9341110
R4, R28 33K Metal film resistor, 1%, 0.25W 2 62-3486 9341757
R12, R32 47K Metal film resistor, 1%, 0.25W 2 62-3490 9341960
R11 62K Metal film resistor, 1%, 0.25W 1 62-3493 9342125
R10 82K Metal film resistor, 1%, 0.25W 1 62-3496 9342281
R18, R7, R31, R33, R29 100k Metal film resistor, 1%, 0.25W 5 62-3498 9341129
R15, R16 150K Metal film resistor, 1%, 0.25W 2 62-3502 9341340
R30 1M Metal film resistor, 1%, 0.25W 1 62-3521 9341137
R8 5K single turn cermet trimpot, top adjust 1 68-0020 9355111
R13 5K multi-turn cermet trimpot, top adjust 1 68-1945 9353291
R9 20K multi-turn cermet trimpot, top adjust 1 68-1947 9353240
RN1 10K 1 + 6 Resistor network 1 2321775
C1, C7, C13, C14 18pF Ceramic capacitor 4 11-3402 2860106
C8, C22 1nF Ceramic capacitor 2 11-3434 2860086
C2, C3, C4, C5, C11, C15, C16, C17, C18, C19, C20, C21, C23, C25 100nF Ceramic capacitor 14 11-3442 2860097
C6, C24 4.7µF Electrolytic capacitor 2 11-3548 2495077
C9, C26, C27, C28 100µF Electrolytic capacitor 4 11-3551 2495078
D1 1N4148 Signal diode 1 47-3309 2322485
D8 1N5819 Schottky diode 1 47-2566 2341584
D9 1N4004 Rectifier diode 1 47-3136 9556109
LED1, LED2, LED3, LED4, LED5, LED6 3mm Super Bright Yellow LED 6 55-0068 2080002
Q1 2N3904 Transistor NPN TO-92 1 81-0484 1574370
Q2 20MHz Crystal 1 90-1084 3264326
OK1 2601 Optocoupler, Digital Output, 1 Channel 1 1328376
IC1 LM4040 Series Voltage Reference, 4.096v 1 3124413
IC2 TL074 Quad op-amp 1 82-0054 3005128
IC3 MCP4822 Digital to Analogue Converter 1 1439413
IC4 ATMEGA644p 20MHz Microcontroller 1 1455122
IC5 74HC595N 8-bit POSI Shift Register 1 82-0265 3120865
IC6 74HC165N 8 Bit PISO Shift Register 1 83-0106 9591206
IC7 MCP6002 op-amp 1 1332117
IC8 7805 5v Linear Voltage Regulator, TO-220 1 47-3550 9666095
SW1 24 detent incremental rotary encoder with switch 1 49-6180 1520813
S1, S2, S3, S4, S5, S6 tactile switch 6 78-0138 2292963
J1, J2, J3, J4, J5, J10 3.5mm Thoniconn jack sockets 6 https://www.thonk.co.uk/shop/thonkiconn/
J9 15v 1A DC power socket 1 20-0960 2450496
JP3, JP4, JP6, JP7, JP8, JP9 TEL 5-1222 DC-DC Converter 9 - 18V DC in ±12V DC out 1 57-4943 1204971
U1 2x3 pin header 1 63-7721 1248159
J7 2x8 pin header 1 19-0035 2215308
X1 5 Way 180 Degree DIN PCB Socket 1 49-4746 2677770
J8 6.35 mm 2 Pin Mono Jack Socket 1 20-0992 2766190
U$3 Newhaven LCD module NHD-0216K1Z-NSW-FBW-L 1
Other items:
IC4 DIP-40 Socket 1 22-1730 2839829
IC5, IC6 DIP-16 Socket 2 22-1722 2839830
IC2 DIP-14 Socket 1 22-1721 2839825
OK1, IC3, IC7 DIP-8 Socket 3 22-1720 2839831
IC8 TO-220 heatsink 1 36-0235 4621281
S1, S2, S3, S4, S5, S6 Switch caps 6
U$3 1x16 pin header for LCD 1 50-8083 3049546
J9 15v 1A PSU 1 85-3756 3532533
you can always just email me if you’re having problems sourcing parts, there are a small number of inaccuracies currently because I’m having to pedal furiously making subs to keep the carts filled with in stock items, someone even made me a list of them.
you can get bom’s in excel format from the github, no conversion needed.
I have 2 pcb l of this spares and flashed chips too.
right, things someone mentioned to me recently were the trimmer, the encoder and the nut, I’ve replaced all those in the cart, everything else should be fine.
I was going to send you an email, but am still recovering from COVID weaponised sinusitis, so my attention span is rather limited at the moment. I assumed that the Mouser BoM was created by someone else, as I’ve found it linked to from other websites too. The main driver for doing it myself, was that various items were out of stock, or on long back order, on Mouser, so I’d need to source them anyway.
I’ve looked in the GitHub repo, but can’t find any sort of BoM.
Well, there’s now two nuts in the BoM 568-NRJ-NUT-MN and 550-1005. The 652-3296Y-1-502LF trimmer should be a 652-3296W-1-502LF, i.e. inline legs. 660-MF1/4DCT52R6192F can just be 62K and 660-MF1/4DCT52R8252F can be 82K. Only need one 821-1N5819A0G diode, not four.
The only thing I haven’t been able to find an equivalent of, is the tactile switch caps. To the point where it might be easier to modify the EPS enclosure file to take round caps.
Frustratingly there isn’t a single UK supplier that has everything, you can only get that resistor network off Farnell for instance, not even from from their CPC sub-domain. :man_shrugging: Also stuff like the VO2601 can be got from RS, but you can only get the 6N137 variant from Farnell. Buying small amounts from Farnell leaves you open to the £5 / £10 small order surcharge, or if you select the wrong thing, the £15.99 US delivery surcharge.
that’s been a bit of a team effort that cart, I started it for v1 then someone else added some bits for v2, then it’s been reworked as bits go out of stock, which has been happening a lot lately :wink:
the cart doesn’t include any of the case hardware, I include all that with cases, I have got mouser numbers for all that stuff that someone sent me, maybe easier to mod the case or file to take round caps if you can’t find them or just make something, you can operate the switches without them if the tester is uncased.
looks like the free version of eagle can still be downloaded, put a link in the other thread, the euro pcb’s all have excel boms (in the “hardware” subfolder), there might be alternative resistor networks and optocouplers available here, or on ebay
incidentally if you aren’t interested in MIDI you can probably do without the optocoupler, or if you can manage without it temporarily
The wonderful world of components sourcing. For one module I did I spent a couple hours searching and it looked like I’d have to order one part from one source and one part from another source, and then I discovered Thonk had both parts, and shipping from England to the US would be cheaper than the combined shipping from the two US companies.
It’s the shipping that’ll kill you in cases like that. I rarely buy from Mouser because most parts I can get cheaper elsewhere, and then the few parts I can’t don’t add up to enough to justify Mouser’s minimum shipping rate which I think is $8 or $9, well above Digi-Key.
But if Mouser is the only place that has all or most of the parts you need it can end up being cheapest to buy from them. You might be best off dealing with Mouser UK.
mouser ship free to the UK with a £33 spend
and if you order the switch caps, they’ll send them separately when they come in, they’ve had them in and out of stock already this year
Link…?
Yeah, the trick seems to be to distribute the components between Rapid, RS and Farnell in such a way that you get passed the small order surcharge with Farnell, but still get free shipping from Rapid and RS, while also not buying multiples of items you’re never going to use again.
It seems totally nonsensical to order anything from the US when I can get it all from UK suppliers.
you need to spend about £30 at farnell rapid and rs to get free shipping don’t you? £20 at cpc I think
There isn’t a module tester / noodle toaster folder in that GitHub repo.
CPC don’t do a 1 + 6 10K resistor network though, neither do Rapid. RS do them, but only if you buy pack of 25.
right, looks you can get the recom in the uk which is around £20, if you don’t want to use the cheaper meanwell unit I found at mouser, that’d get you quite a way to free shipping from one UK supplier, take that, lcd and switches off the mouser cart and you’d be left with about £40, well above free shipping threshold so you could drop off some of the stuff you can get cheaper here, checked the cart and the red switch caps I found are still in stock there, so you could get all the fiddly stuff from mouser and hopefully then all the more common stuff from the same place that sells the recom, mouser charge UK vat at checkout so you don’t need to pay anything extra for customs handling, it just gets delivered in about 2-3 days normally.
I’ve gone ahead and added a KiCad version to the forked repo, just an import of the Eagle files, and with a BOM auto-generated from the schematic: module_tester/module_tester-v02_bom.md at master · holmesrichards/module_tester · GitHub
Took a punt on a TS100 soldering iron, so purchased all the necessary components to get on and get this built. All except the 3296W 20k trim POT, as both Rapid and Farnell are out of stock till late next month. Thonk have BAOTER ones for 60p, but £2.58 P&P. Buying one off eBay is only 18p cheaper, so Thonk it is then… :disappointed:
I decided to build one of these. Decided I wanted to re-dimension the PCB, to better fit an existing enclosure, and to change a couple of the footprints (1/4" jack and MIDI socket) to match components I already have. So I modified the imported Eagle files in KiCad. While I was at it I modified the footprints to get refs and values on the silkscreen (the resistors had NEITHER!) and decided to use a right angle header for the ribbon cable. And I added mounting holes for the LCD just in case I decide I want them. I’ve just placed the fab order.
Have you thought about what you’re going to do for a case…? Turns out I know someone with a laser cutter, so in discussions to see if he’ll cut some perspex for me.
