Hey, maybe there is another noob like me out there who needs help getting the Super Simple Fuzz onto a stripboard. So today I built one and quickly painted it. Probably it can be more elegant? But it works! By the way i used a 220k resistor because i had no other one…it still works!
The Bypass switch means, if its off, the Signal goes “clean” trough the box and when its “on” you have the Overdrive effect, right ? Because my box just have the “on” Modus, when i turn the pot to the left, no Signal is getting through the Output.
@analogoutput if it can be, could you please explain how to to? (you know, I´m very new to this)
That would be great because i also don´t have DPDT Switches here at the moment.
The page I linked to goes over how to do true bypass (which requires at least a DPDT) but turns out he also cover some alternatives elsewhere; in your case “Mechanical output switching” on this page http://stinkfoot.se/archives/501 might be what you’re looking for.
as @fredrik says, for a real bypass, because being a guitarist with the pedals without true byepass slightly modifies the original sound and like most of the guitarists we have a certain quantity in series and at the end of the chain it is the disaster
What is VR1?
Apologies for my ignorance as I’m new to the hobby. I’m assuming it’s a voltage regulator? If so, what specs do you need and what is it needed for?
Welcome! Abbreviations appear often in schematics to save space. Most are straightforward 1st letter reduction but even then there are old terms that creep in and then, as there are no DAQ*s on the road to JFDI Accreditation, you can Google or ask here. All of us remember our start in this universe. Crack on!
Oh that makes so much more sense! I’m getting more familiar with the abbresviations but having the image show VR1 in the diagram and then 2x POT in the list threw me off… I often see diagrams with POT written on there.
Which then leads me onto my second *DumbA$$Question haha… the list says 2x POT so is that a mistake? I don’t see a second pot anywhere
Plus a bonus question while I’m here: whats the easiest way to convert this diagram to a perf board?
