Rene's YASH on Stripboard
Hi
I’ve been lurking around this discourse for a while and wanted to share my first schematic to stripboard conversion.
Its directly copied from the schematic on Rene Schmitz site.
OG-YASH
I haven’t tested this yet so no idea if it will work. Feel free to point out any errors.
I’m building this tonight and will post my progress. Cheers!
Fixed some errors after triple checking. Still unverified.
Welcome in the forum, and when it’s verified you can post it here :wink:
Good work! It is good practice to label unverified layouts as such to help people who are arriving here from the net. Would you mind re-uploading the image with a little “unverified” on it?
Thanks man. Uploaded with a couple of errors fixed and UNVERIFIED marking.
I built it out and its not working. Anyone have any troubleshooting advice? As far as I can tell the wiring is correct. Using a multimeter I can see that that the internal oscillator is working. The LED is not lighting up but there is fluctuating volts on the positive leg and on the collector of the transistor.
If I measure the output it is very low.
Here it looks to me like +12 V connects to the 2.2k, which then connects directly to the Q1 collector. That’s wrong, isn’t it?
Yes it is. It should be after the diode. I’ll make the alteration. Thank you so much.
The led is flashing and I have a nice square wave on the collector and base of the transistor. However the signal that is coming out of the LF398 chip is still low and doesn’t seem to be effecting the 3340 VCO I’m testing it with.
If I look at it with an oscilloscpe it seems all over the place. I am using a square wave from the same vco as a source then coming out of the sample and hold back into the CV on the 3340 VCO. Then I have the triangle output going to a small test amp.
I am using a polypropylene capacitor in place of a polystrene cap.
If you’re sampling an audio frequency square wave at low frequency then you should get either maximum or minimum values out essentially at random. If you’re seeing intermediate values then something’s not right.
An LFO input, say a ramp or triangle wave with frequency well below the clock, might be better for diagnosing.
Do you get something like 3 µs pulses with amplitude ~ 2.5 V at LM398 pin 8?
I don’t see any further errors in the layout and assuming you get good pulses into pin 8 the rest is up to the LM398, so the only possibilities I can think of are assembly errors or defective chip.
Thanks so much for looking over my layout. Probably an assembly error there is some weirdness going on with the board. I’m going to build out another one. Will update with my findings.
I don’t know if that can help you but @EddyBergman made also a stripboard layout for it
:face_with_monocle:
Thanks I have seen that one and its great but I was trying to build something a bit smaller as my synth is Eurorack based.
Had a troubleshooting session. Just got myself an oscilloscope but I have no idea how to use it :smiley:
No idea how to read it or measure the pulse.
I am using a Doepfer LFO on the input and running the output into a 3340 VCO. I am getting a slow clicking sound that seems to be in sync with the internal trigger on the board.
The chip is getting quite hot as well. I checked for shorts and didn’t find any.
I suspect the capacitor isn’t holding the charge. I got a polypropylene 1n cap off ebay. I’ll order a polystyrene one.
any advice welcome :slight_smile:
Order a polystyrene dozen. Buying parts one or two at a time is expensive.
Post pictures of your build? Both sides?
There must be good videos on how to use a scope. I’ve never watched any because I learned in physics lab circa 1974.
I’m getting through the oscilloscope vids on YouTube :wink:
In the meantime here’s the board front and back.
The angle of the photo can make it hard to tell, but I have a feeling the longer yellow link to the bottom left of IC2 is incorrectly located. In the layout at the top of the post with grid references, I think o9 and N9 may have become switched.
O9 and N9 and tied together so that shouldn’t matter.
I did notice that when I looked at the image still open on my screen this morning.
I think its either an issue with the capacitor or chip holder as I’ve had issue with them before. Building another board tonight.
Rebuilt the board and its working this time. Not sure what the issue is with the other board possibly a bad IC socket. Here’s the final layout I used.
What a journey :smiley:
