Cool! You seem to have quite some audio sources already, but not so much to modulate and modify them with. I’d say you could use some ADSRs, an LFO, and some audio effects, maybe delay?
Cheers!
Cheers!
More here: STUFF - LOOK MUM NO COMPUTER
Happy for you, yes some fx, maybe also some drum modules.
btw have you calibrate your octave switch on the VCO ? look not good for my ears
Dud I havent calibrated anything. I dont have a 7 segment display or the Arduino so it is raw. I am not one for tuning really. The only thing I tune are the antenna’s above my house (thats for any other Ham Radio nuts out there). I have 4 Barton Analogue Drum modules that you can see at the start of the video. Top right of the case. I didnt have them patched in.
You could have with a guitar tuner or that of a friend, there are also some on the phone …, but if it is a choice, indeed no interest, sorry
I might have a look at one on the IPhone. Thanks mate.
Looking good. Im happy you mentioned your old cassette player, it adds character to your rack.
Drawing the face plates and sticking them to a rack, seems like a really good idea, so simple, yet why did i not think of it. I have started to draw a rack out in cad, but seeing things in the rack like this may well help influence design decisions.
Exact, it is very nice for visualising the rack and makes planning easy.
I’ve drawn on 5mm grid paper, and when i am satisfied with the layout it is very easy to transport to frontpanel designer to get accurate drilling templates out of the printer.
I remember paper and pencil. I do my panel designs in Inkscape, though. Then either print them and stick them with a transparent film layer onto aluminum for a one-off homemade panel, or (mostly these days) pull them into KiCad to make Gerbers for fabricated panels. But that’s partly because I’m obsessive about making my panels more neatly than I could manage by hand. And if I want to see how my case is going to look, well, I just pull all my module designs together into an Inkscape file and start shoving them around.
Well, I mean, I can see how you’d need an index. Preferably alphabetized and cross referenced.
Tip: when you design your Kosmo panels, use standardized widths, like 5CM for small projects, 8CM for bigger and 10CM for things like VCO’s and ADSR’s. That makes it easier to swap and re-arrange modules if you want to make a different setup. I started out making each one just the size it needed to be and if I now want to change modules I have big problems making it all fit.
(I’m a multiples-of-2.5 kind of guy.)
Blasphemy! Heresy! ![]()
Whatever suits you mate. I’m saying, standardize, to whatever measurements you like
Makes life easier.
i use 3, 4, 8 10 and 15 cm. My case is not an even number because of scrap woods and that are the sizes of material i can get quite easy!
I have built almost all the pcb’s that need to go behind the panels by the way, just need some moolah to finish the builds. i’m not just paperdreaming haha
