just to let you know! rob over at molten modular is building his first kosmo stuff today 8pm GMT+1 I think
thats the link, he says this is the first project he has had to source the components and stuff, ill pop on the stream at some point im not sure when yet! to chat about it. maybe if you have some insight pop over!
If people interested in cooperative streams post here saying when they’re available (from, to), additionally giving time zone and daylight savings switch date if any, it will encourage matching.
During that stream, someone mentioned a 79L05 -5V regulator being used in the Kassutronics VCO
@lookmumnocomputer started looking for it in the schematic, and I got curious too, but as it seems to be only used as the 3340’s VEE negative power rail, (and the schematic is sideways in the pdf found on the Internet) we didn’t find it immediately so Sam didn’t get to comment on it.
The buit-in Zener diode shown in the CEM3340 datasheet and relied on in Sam’s VCO design is fine, but does anybody know if using an active regulator could help with the issue of the pulse width affecting the frequency?
The Kassutronics documentation only says: “this module uses onboard voltage regulators to reduce sensitivity to power supply fluctuations and limit self-heating of the VCO chip”, so it doesn’t seem that the pulse width issue was a factor in choosing to use the 79L05.
I built the Kassutronics module, but I have no idea. I tend to leave the PW in the middle, so I haven’t noticed the issue on the Kosmo VCO either. Would I be able to tell the tune drifting if I dial it to the extremes?
I haven’t witnessed the effect myself (I haven’t looked for it) but, yeah, that is my undestanding: as you change the pulse width towards an extreme, the oscillator frequency changes, even for the other waveforms, so it should be pretty easy to hear, if you listen to only the sawtooth or triangle while twisting the pulse width knob.
I’m chipping in here as pwm as an effect can affect perception of frequency. My physics is well dusty but I believe the pitch change you hear is similar to the Doppler effect and is a matter of observational ‘bias’ (ok so now im winging it while making a plea to the physics crew out there that always swoop to my rescue when I overreach like this … guys…any time now…any second… you wait and see… confirmation is but a moment away… oh it’s Sunday, so soon …)
Mine aren’t built yet, but for what I have read the frequency really changes.
If you just listen to the triangle out, change PWM width, and the freq of the triangle changes.
As for pitch perception, when you change the PWM width, you change the harmonics content of the signal, this can (will ?) change your perception of the pitch.
Frequency only applies to a periodical signal, which most of traditional instruments DON’T produce.
Pitch is perceptual by definition/necessity.
I can test this in a builders stream later in the week, I dont think it will help as it feeds the same zener diode. but who knows.
in the second version (got a dual cem3340 oscillator Sith 1 tuner and wideness instead) it’ll have comparators doing the PWM so the square wave in the chip isn’t touched:D.
as for the -5v in the kassutronics, a lot of Roland gear does that. truth be told I didn’t bother as it added more components, as in 4 extra components to bypass 1 resistor didnt make sense to me.
edit. might be more the actual capacitor wired to the negative supply. plonking a larger like 470n onto it even. that might be worth a go for Pwm drift. ill devote a builders livestream to this issue within the week we can try some stuff out
