Yeah, OLEDs are as easy to work with as character lcd screens now, only with more space and capabilities etc.
Stuff all this complicated gimmickry. I was hoping to have a simple LFO to split out to more than one source. Getting divides of the pulse in multiple outs was cool. Getting maybe the LFO in a digital source that can skip through in a Euclidean way would be nice. Make a few presets and put them on some mini switches and menus aren’t necessary. Guide the function with a few 3mm LEDs and OLEDs aren’t necessary. I thought around 10cm width but mostly to make those outputs breathe.
Sounds to me like you just want a multiple + LFO.
This is with triangle rather than pulse signals, but it was one of the most popular eurorack modules of the year. I made a Rack version that’s one of my most popular modules. Basically the idea is that since most other modules have CV parameter modulation… well, then Modulate All The Things^tm. It’s very useful for ambient soundscapes and generative music. I’d love a Kosmo Ochd.
ive been wondering about the circuit for that.
(ochd that is)
Caustic,
My want is explained above: I saw the Novation Peak had a global LFO. I’ve been trying to plan my Kosmo on what I see in hardware synthesizers and the only thing missing from the VCLFO was some simple LFO with multiple outputs, like a global LFO. Though a trick, two or three like divided tempos by 1/2 and 1/4 or skipped phases like a Euclidean sequencer wouldn’t be refused. I mean slim as it hasn’t become bloated with featurejam beyond its purpose of keeping multiple inputs on the same LFO. Not too gimmicky or complicated of a multiple clock/LFO/sequencer was my initial dream.
I’ve been trying to figure this out too. It looks like there are 8 (or 4?) SMDs ICs on the board, but I can’t see what they are. I think they are Wien bridge oscillator - Wikipedia based oscillators.
Wien bridge oscillators produce sine waves, not triangle waves, and are a bit tricky to control by voltage since you need to change multiple component values at the same time (and you also need to do some trickery to get them to oscillate in the first place).
Triangle waves are easy to make; just set things up so you charge and discharge a capacitor with a constant current, and the voltage across the capacitor will be a perfect triangle wave (or you can cheat and charge and discharge with a constant voltage across through a resistor; that won’t give you perfect triangles, but may be good enough). The trickery here appears to be how this thing is controlled (the description doesn’t really explain much).
(if you want a bunch of fixed sine wave oscillators, see here)
so a bit of an update today on facebook I stumbled upon Tim Nijssen’s project which looks like a cool clock distributor! its a pcbs project give him a message if you Are interested! https://www.facebook.com/groups/549267875688193/user/1421697171/
search up Tims name on Facebook you can add him and message him there ![]()
Or you can probably ping him here, right @TimMJN ![]()
Good work @TimMJN!
It’s not a module I need now, but I’ve bookmarked it for when I do.
Thanks for the shoutout Sam! I can be contacted right here, no worries. PCBs are up in the buy-sell threat: The BST Thread (Buy, Sell, Trade) - #133 by TimMJN
They are going kinda quickly, but I will do another run!
I think it looks awesome. I feel kind of dumb I can’t figure out how I’d use it.
Apart from being a normal clock divider, the rotate function allows you to generate complex “polyrhythms”. I put that in quotes, since it’s not polyrhythms in the classical synth sense, ie multiple rhythmic voices with different sequence lengths. Rather, the rhythm becomes a series of N pulses at X clock rate, followed by M pulses at Y clock rate etc. Depending on how you trigger the rotation, the sequence might not repeat for a very long time. I’ve found an excellent example here:
Also, it tracks accurately up to a few kHz, so you could even use it to make pulse wave chords.
I want to bump awareness of something I vaguely put out there earlier. I’m excited maybe someday I’ll release modules. Until I do I wanted to put the awareness out there of other quad LFO sources like 4ms Quad Pingable LFO and Xaoc Batumi. It would be nice having a utility not too fancy multiple LFO and external sync. I see global LFO’s on non modular synths like Novation Peak but modular people seem to not consider they added more VCO’s than they could ever need but they ran out of LFO’s. I might be interested in collaboration on a multiple. It does look like an LFO and a multiple but when you consider having different LFO’s with a tap tempo it’s a bit greater.
thanks kardashev, synced up LFO’s??? its quite funny as I was planning a 6 lfo set but un synced, I have never really found a need for synced LFO’s found the need for out of sync ones phasing? the VCLFO’s have sync, maybe a duel version with less knobs could be cool, it can be synced and not synced, there is also that clock source out in the wind! by Tim
Sam,
I’ve heard that some of the multiple LFO’s have phasing options which I would think is loads of fun! You could have for example each LFO one 90 degree ahead on the cycle. Yes dual LFO’s is all I think is not in the picture maybe quad is a lot.
I started working on a quad/oct LFO (basically a DivKid Ochd in Kosmo format), which doesn’t have sync but does have a master control knob with CV input and an attenuator. I think with real sync and division it’ll be a lot harder or will require lots of Electric Druid chips.
