You never know, @Dud might need to borrow it
It has the perfect lenght
“It WILL go”
all my cables seem to short, longer jack cables seemed cheap until I needed lots of them
You just need the right-angle kind
Didja know if you connect a 10 V shunt voltage reference backwards, and power it with a supply that’s putting out about 11.5 V, then you still get something that’s kinda sorta near 10 V? But not really?
Also, symbols meant for use with SOT-23 footprints should not be used with TO-92 footprints. Or so I’ve heard. Someone did that and it didn’t work apparently.
How have I managed to get this far without putting “check power connection polarity on chips” in my pre-fabrication checklist?
down to trusting yourself
A couple of months ago, I moved my TV to put my rig in the middle of my room, put the case on the shelf, screwed it to the wall, put modules infront of those screws. Well tonight I thought I would watch some telly, where is the power lead!!!
Trapped between the shelf and the case!!! Decided it would be easier to buy a new lead than move it all
I had some problem of “clic” sound on my VCDO Additive module
i change to the FM version, work well when i tested it …
and today i want to do a vid for my webblog, and … Clic Clic Clic
The real problem is when i used a trigger sigal, go in an Envelope then in a Buffered Multiple and in a VCA
i have some clic
if i Multiply the Trigger signal and after in an Envelope G (then in a VCA) all is clear like some water
so i change the Additive for a FM for nothing, it wasn’t the module but my patch.
I ll build an Additive for my next case
Nothing a bit of paint can’t fix…
so you will have a , before - after - after the after - before the next after …
Ok, I’ve fixed the attenuator pot pins. They’re the right way around.
ticks PCB checklist
sends PCB to fab
Well, I guess I didn’t fix the other 6.
Maybe the checklist should say “attenuator potS pins”.
It says “check pots are oriented correctly”
Revised to “check ALL pots are oriented correctly”
Also I need a “don’t just skip a step and assume it’s OK”
ah shit thats A-1617 not A-1627
the real shitty part is I already placed the order for the things I knew I forgot .
Oh, no, you’ve got 14 of the wrong sliders?
15 bought one extra just in case …
