OK… I said TL072 because only two op amps are used. A TL072 contains two, a TL074 contains four. It’s kind of silly to use a TL074 here unless something else is being added to the circuit that uses more op amps. And in fact a TL072 is shown on the stripboard instead of a TL074.
Anyway, TL074:
There are five pieces to this one IC, here is one:
(pins 1, 2, 3); here is another:
(pins 5, 6, 7); there are two more not shown, pins 8, 9, 10 and pins 12, 13, 14, which are the two unused op amps, and finally there is this piece:
They’re drawn in different parts of the schematic (or not drawn at all) but all are part of one IC. Pins 4 and 11 are the power pins.
If you use a TL074 you should not leave pins 8, 9, 10, 12, 13, and 14 dangling. You should connect pin 8 to pin 9, connect pin 13 to pin 14, and connect pins 7 and 12 to ground.
Or you can just use a TL072 in which case there are only 8 pins and 1, 2, 3, 5, 6, and 7 are connected the same as with the TL074. +12 V connects to pin 8 and -12 V connects to pin 4.
