Cheap Component Search
if done right, these modules and format wont be that expensive at all. for instance im finishing off an envelope generator now that after panel/pcb the parts would be overall £6/7. stuff like the filter is under £10 and the vclfo is not far off! so please chat parts that relate to all of the modules on this topic!
MOLEX connectors the cheap ones at rapid your looking at about 30p each :
https://www.rapidonline.com/Catalogue/Search?Query=JYK%20P2500&Size=20
however caustic over on my Patreon has pointed out on tayda they are under 10p! well under :-
4 Pin variety as a comparison:
Mouser: $0.40 / £0.31
Rapid: $0.24 / £0.19
Tayda: $0.04 / £0.03
Housing connector:
Tayda: $0.03/ £0.023
Crimp Terminal Connectors:
Tayda:$0.03 / £0.023
PINS:
https://www.taydaelectronics.com/wafer-connector-2-54mm-4-pins.html
Housing:
https://www.taydaelectronics.com/connectors-sockets/wafer-housing-crimp-terminal/serie-2500-2-54mm/housing-connector-2-54mm-4-pins.html
Terminal Connectors (IMPORTANT)
https://www.taydaelectronics.com/crimp-terminal-connector-2-54mm.html
" by 42kn355
Regarding US suppliers
Some of my favorites have been -
Modular Addict - 9mm Alpha Pots, Knobs, DIY PCB’s, etc.
SynthCube - Obscure Jacks and other various Modular Supplies.
SparkFun - This is specifically where I get my 2 Pin Molex Connectors, but they have tons of other stuff as well.
Love My Switches - I often buy the TruConnect 1/4" Jacks from here.
Perfect Circuit - Great for Eurorack 16 to 10 Pin Cables, and other various supplies.
There are some obvious others for really common parts, like Tayda, Mouser, etc.
For IC’s I often utilize Amazon Prime and Ebay.
Over the last year, having Amazon Prime has probably saved me over 300 in shipping on random parts orders… lol
Hope some of these help others!"
JACK SOCKETS :-
I can confirm these work and are nice and cheap!
https://www.mouser.co.uk/ProductDetail/REAN-Neutrik/NYS232?qs=%2Fha2pyFadugmnx0kZ8I0yxhALEezTEMSgSeTGJnT%2B4ByD9HE33EqVg%3D%3D
Also these depending on stock:
and
https://www.taydaelectronics.com/6-35mm-1-4-stereo-phone-jack.html
I suppose I’ll have to buy a job lot of big jack cables and big sockets. I also need some larger-value capacitors, I think I’ve got plenty of lower value ones. Lots of resistors, LEDs, and a decent amount of stripboard. One module I may experiment with will be a solderless breadboard with a Eurorack power supply on the rails and a few pots, switches and jacks. I may use some of Mutable Instruments Breadboard Friends (link below).
The board must be easily removable so I can build a board on the desk and plug it in. Perhaps I’ll turn the panel into a small door that the breadboard can be clipped behind.
https://mutable-instruments.net/archive/bbf/
Caustic mentioned Tayda announcing monthly sales on their Facebook. Now is that time. 15% Discount Coupon Code : “Sale15”
**Valid till 24 January 2020 ( 11pm New York time )
**Valid to use only on www.taydaelectronics.com
**Please make sure to apply discount coupon during checkout, we can’t apply it manually after checkout is completed.
Happy Shopping!
Thank you for choosing us.
Hey all,
I took some time and collected links of common components used in these projects.
Tayda lets you group Favorited components so you can just add a bunch of items to the cart at once. Good for stuff you run out of a lot like jacks and pots.
6.35mm jacks
6.35MM 1/4" STEREO PHONE JACK
$0.45 £0.35
Molex / Wafer Connector bits
(Image lies, check the details to be sure you get the right pins you need. You will also want a crimper.)
WAFER CONNECTOR 2.54MM 4 PINS
$0.04 £0.031
HOUSING CONNECTOR 2.54MM 4 PINS
https://www.taydaelectronics.com/housing-connector-2-54mm-4-pins.html
$0.03 £0.023
CRIMP TERMINAL CONNECTOR 2.54MM
$0.03 £0.023
Capacitors
SAVE TIME EASY ORDERING PAGE FOR CERAMIC DISC CAPACITORS
https://www.taydaelectronics.com/capacitors/ceramic-disc-capacitors/test-group-2.html
$0.01 £0.0077
Electrolytic Capacitors
https://www.taydaelectronics.com/capacitors/electrolytic-capacitors.html
$0.02-0.85 £0.015-0.65
10UF 25V 105C RADIAL ELECTROLYTIC CAPACITOR 5X11MM
https://www.taydaelectronics.com/10uf-25v-105c-radial-electrolytic-capacitor-5x11mm.html
$0.02 £0.015
1UF 50V 105C RADIAL ELECTROLYTIC CAPACITOR 5X11MM NICHICON
https://www.taydaelectronics.com/nichicon-1uf-50v-105c-radial-electrolytic-capacitor-5-11mm.html
$0.15 £0.12
$0.02 £0.015
100UF 10V 105C RADIAL ELECTROLYTIC CAPACITOR 5X11MM
https://www.taydaelectronics.com/100uf-10v-105c-radial-electrolytic-capacitor-5x11mm.html
$0.03 £0.023
4700UF 25V 105C RADIAL ELECTROLYTIC CAPACITOR 16X26MM
https://www.taydaelectronics.com/4700uf-25v-105c-radial-electrolytic-capacitor-16x26mm.html
$0.60 £0.46
100UF 35V 105C RADIAL ELECTROLYTIC CAPACITOR 6X11MM
https://www.taydaelectronics.com/100uf-35v-105c-radial-electrolytic-capacitor-6x11mm.html
$0.03 £0.023
Resistors
SAVE TIME EASY ORDERING PAGE FOR 1/4W 1% RESISTORS
https://www.taydaelectronics.com/test-group-2-2762.html
$0.012 £0.0092
SAVE TIME EASY ORDERING PAGE FOR 1/4W 5% RESISTORS
https://www.taydaelectronics.com/test-group-2-2761.html
$0.01 £0.0077
PHOTO CONDUCTIVE CELL RESISTOR LDR 650NM RADIAL KE-10720
https://www.taydaelectronics.com/photo-conductive-cell-resistor-ldr-650nm-radial-ke-10720.html
$0.24 £0.18
Ribbon Cable
10 CONDUCTOR AWG 28 FLAT RIBBON CABLE 1FT (30CM)
https://www.taydaelectronics.com/awg-28-10-conductor-flat-ribbon-cable-1ft-30cm.html
$0.20 £0.15
16 CONDUCTOR AWG 28 FLAT RIBBON CABLE 1FT (30CM)
https://www.taydaelectronics.com/hardware/cable-wire/awg-28-16-conductor-flat-ribbon-cable-1ft-30cm.html
$0.33 £0.25
IDC SOCKET CONNECTOR 2.54MM 2*5 PIN
https://www.taydaelectronics.com/idc-socket-connector-2-54mm-2-5-pin.html
$0.16 £0.12
IDC SOCKET CONNECTOR 2.54MM 2*8 PIN DOUBLE CONTACT
https://www.taydaelectronics.com/connectors-sockets/box-header-connectors/idc-socket-connector-2-54mm-2-8-pin.html
$0.30 £0.23
16 PIN BOX HEADER CONNECTOR 2.54MM 2*8PIN
https://www.taydaelectronics.com/connectors-sockets/box-header-connectors/16-pin-box-header-connector-2-54mm.html
$0.18 £0.14
10 PIN BOX HEADER CONNECTOR 2.54MM 2*5PIN
https://www.taydaelectronics.com/connectors-sockets/box-header-connectors/10-pin-box-header-connector-2-54mm.html
$0.14 £0.11
Timer ICs
NE555 IC 555 TIMER PDIP-8
https://www.taydaelectronics.com/ne555-ic-555-texas-timer.html
$0.16 £0.12
Memory ICs
24LC512-I/P 24LC512 512KBIT SERIAL IC I2C SERIAL EEPROM IC
https://www.taydaelectronics.com/ic-integrated-circuits/memory-ic/24lc512-i-p-24lc512-24512-512k-ic-i2c-serial-eeprom-ic-microchip.html
$1.97 £1.51
OP-AMP ICs
LM13700 LM13700N OPERATIONAL AMPLIFIER IC
https://www.taydaelectronics.com/lm13700-lm13700n-operational-amplifier-ic.html
$2.02 £1.55
TL072 LOW NOISE J-FET DUAL OP-AMP IC
https://www.taydaelectronics.com/tl072-low-noise-j-fet-dual-op-amp-ic.html
$0.34 £0.26
TL074 QUAD OPERATIONAL AMPLIFIER J-FET PDIP-14 TL074CN
https://www.taydaelectronics.com/tl074-quad-operational-amplifier-j-fet-pdip-14-tl074cn.html
$0.49 £0.38
74xxxx ICs
74HC595 8 BIT SHIFT REGISTER IC
https://www.taydaelectronics.com/74hc595-8-bit-shift-register-ic.html
$0.29 £0.22
74LS00 7400 QUAD 2-INPUT NAND GATE IC
https://www.taydaelectronics.com/74ls00-7400-quad-2-input-nand-gate-ic.html
$0.29 £0.22
74LS04 HEX INVERTER IC
https://www.taydaelectronics.com/74ls04-hex-inverter-ic.html
$0.69 £0.53
74LS08 7408 QUADRUPLE 2 INPUT POSITIVE AND GATE IC
https://www.taydaelectronics.com/74ls08-7408-quadruple-2-input-positive-and-gate-ic.html
$0.44 £0.34
74LS32 7432 QUADRUPLE 2 INPUT POSITIVE OR GATE IC
https://www.taydaelectronics.com/74ls32-7432-quadruple-2-input-positive-or-gate-ic.html
$0.38 £0.29
74LS138 (3-to-8 line decoder)
https://www.taydaelectronics.com/ic-integrated-circuits/74-series/74ls-series/74ls138-74138-decoder-demultiplexer-ic.html
$0.99 £0.76
IC sockets
8 PIN DIP IC SOCKET ADAPTOR SOLDER TYPE
https://www.taydaelectronics.com/connectors-sockets/sockets/8-pin-dip-ic-socket-adaptor-solder-type.html
$0.03 £0.023
14 PIN DIP IC SOCKET ADAPTOR SOLDER TYPE
https://www.taydaelectronics.com/connectors-sockets/sockets/14-pin-dip-ic-socket-adaptor-solder-type.html
$0.05 £0.038
16 PIN DIP IC SOCKET ADAPTOR SOLDER TYPE
https://www.taydaelectronics.com/16-pin-dip-ic-socket-adaptor-solder-type.html
$0.06 £0.046
Potentiometer
LINEAR TAPER POTENTIOMETER 6.35MM diameter
https://www.taydaelectronics.com/catalogsearch/result/?q=linear+potentiometer+6.35MM
$0.50-0.59 £0.38-0.45
Trimmers
https://www.taydaelectronics.com/potentiometer-variable-resistors/trimmers.html
$0.06-$0.08 £0.046-0.061
Cermet
https://www.taydaelectronics.com/potentiometer-variable-resistors/cermet-potentiometers.html
$0.19-0.28 £0.15-0.21
Knobs
(24MM are the small ones, 33MM look good for things like the performance filter.)
ALUMINUM KNOB 24MM (Blank, no numbers)
https://www.taydaelectronics.com/potentiometer-variable-resistors/knobs/aluminum-knob.html
$0.45 £0.35
ALUMINUM KNOB 24MM (Lines and numbers)
https://www.taydaelectronics.com/potentiometer-variable-resistors/knobs/aluminum-knob-3191.html
$0.48 £0.37
ALUMINUM KNOB 37MM (Blank, no numbers)
https://www.taydaelectronics.com/potentiometer-variable-resistors/knobs/34417-dup-aluminum-knob.html
$0.48 £0.37
ALUMINUM KNOB 37MM (Lines and numbers)
https://www.taydaelectronics.com/potentiometer-variable-resistors/knobs/39133-dup-aluminum-knob.html
$0.48 £0.37
BOSS STYLE SILVER TOP BLACK KNOB 33MM
https://www.taydaelectronics.com/potentiometer-variable-resistors/knobs/boss-style-silver-top-black-knob-33mm.html
$0.39 £0.30
BOSS STYLE SILVER TOP BLACK KNOB 27MM
https://www.taydaelectronics.com/potentiometer-variable-resistors/knobs/boss-style-black-knob-with-silver-top-27mm.html
$0.56 £0.43
Voltage Regulators
L7812CV LM7812 L7812 7812 VOLTAGE REGULATOR IC + 12V 1.5A
https://www.taydaelectronics.com/l7812cv-lm7812-l7812-voltage-regulator-ic-12v-1-5a.html
$0.23 £0.18
L7912CV LM7912 L7912 7912 VOLTAGE REGULATOR IC -12V 1.5A
https://www.taydaelectronics.com/l7912cv-lm7912-l7912-7912-voltage-regulator-ic-12v-1-5a.html
$0.24 £0.18
L78L05ACZ L78L05 78L05 +5 VOLTS 100MA VOLTAGE REGULATOR IC
https://www.taydaelectronics.com/l78l05acz-l78l05-78l05-5-volts-100ma-voltage-regulator-ic.html
$0.09 £0.069
Hardware
HEATSINK TO-220 4 FINS ALUMINIUM
https://www.taydaelectronics.com/heatsink-to-220-4-fins-aluminium.html
$0.24 £0.18
DC POWER JACK 2.1MM BARREL-TYPE PCB MOUNT
https://www.taydaelectronics.com/dc-power-jack-2-1mm-barrel-type-pcb-mount.html
$0.16 £0.12
WASHER 3.3MM FOR SCREW M3
https://www.taydaelectronics.com/washer-3-3mm-for-screw-m3.html
$0.02 £0.015
NUT 3MM FOR SCREW M3
https://www.taydaelectronics.com/nut-3mm-for-screw-m3.html
$0.02 £0.015
M3 STAINLESS STEEL SCREW
https://www.taydaelectronics.com/hardware/nuts-washers-screws-spacers-and-more/screws.html
$0.02 £0.015
BRASS STANDOFF SPACER GOLDEN SCREW
https://www.taydaelectronics.com/hardware/nuts-washers-screws-spacers-and-more/spacers.html
$0.12-0.17 £0.092-0.13
Stripboard
BIG STRIPBOARD 110X93MM (COPPER)
https://www.taydaelectronics.com/big-stripboard-110x93mm-copper.html
$1.29 £0.99
Transistors
2N3704 NPN GENERAL PURPOSE TRANSISTOR
https://www.taydaelectronics.com/2n3704-npn-general-purpose-transistor.html
$0.11 £0.084
BC558 BC558B TRANSISTOR PNP 0.1A 30V
https://www.taydaelectronics.com/bc558-bc558b-transistor-pnp-0-1a-30v.html
$0.04 £0.031
Switch
MINI TOGGLE SWITCH SPDT ON-ON
https://www.taydaelectronics.com/mini-toggle-switch-spdt-on-on.html
$0.47 £0.36
MINI TOGGLE SWITCH DPDT ON-ON
https://www.taydaelectronics.com/mini-toggle-switch-dpdt-on-on.html
$0.59 £0.45
MINI TOGGLE SWITCH 1M SERIES SPDT ON-OFF-MOM
Also known as ON-OFF-(ON)
https://www.taydaelectronics.com/new-arrivals-1/mini-toggle-switch-1m-series-spdt-on-off-mom.html
$1.00 £0.72
DIP SWITCH 4 POSITIONS GOLD PLATED CONTACTS TOP ACTUATED
https://www.taydaelectronics.com/dip-switch-4-positions-gold-plated-contacts-top-actuated.html
$0.27 £0.21
ROCKER SWITCH BLACK ON/OFF DPST 6A 250VAC PANEL MOUNT, SNAP-IN
https://www.taydaelectronics.com/rocker-switch-black-on-off-dpst-6a-250vac-panel-mount-snap-in.html
$0.29 £0.22
TACT SWITCH 6X6MM 5MM THROUGH HOLE SPST-NO
https://www.taydaelectronics.com/tact-switch-6x6mm-5mm-through-hole-spst-no.html
$0.04 £0.031
TACTILE SWITCH CAPS BLACK COLOR 5.3X10MM
https://www.taydaelectronics.com/potentiometer-variable-resistors/knobs/tactile-switch-caps-black-color.html
$0.10 £0.077
Diode
1N4004 DIODE 1A 400V
https://www.taydaelectronics.com/1n4004-diode-1a-400v.html
$0.02 £0.015
Button
PUSH BUTTON MOMENTARY PANEL MOUNT BLACK KNOB SPST-NO
https://www.taydaelectronics.com/pb-11d02-push-button-panel-mount-spst-no-pb-11d02-th1-00.html
$0.25 £0.19
PUSH BUTTON MOMENTARY PANEL MOUNT RED KNOB SPST-NO
https://www.taydaelectronics.com/pb-11d02-push-button-panel-mount-spst-no-pb-11d02-th1r00.html
$0.22 £0.17
Arduino NANO clone
NANO 3.0 CONTROLLER COMPATIBLE WITH ARDUINO NANO CH340 USB DRIVER
https://www.taydaelectronics.com/nano-3-0-controller-compatible-with-arduino-nano-ch340-usb-driver.html
$3.69 £2.83
LED 3-5mm
LED 3MM RED
https://www.taydaelectronics.com/leds/round-leds/3mm-leds/led-3mm-red.html
$0.02 £0.015
LED 5MM RED
https://www.taydaelectronics.com/leds/round-leds/5mm-leds/led-5mm-red.html
$0.03 £0.023
LED 3MM GREEN
https://www.taydaelectronics.com/leds/round-leds/3mm-leds/led-3mm-green.html
$0.02 £0.015
LED 5MM GREEN
https://www.taydaelectronics.com/leds/round-leds/5mm-leds/led-5mm-green.html
$0.03 £0.023
LED 3MM YELLOW
https://www.taydaelectronics.com/leds/round-leds/3mm-leds/led-3mm-yellow.html
$0.02 £0.015
LED 5MM YELLOW
https://www.taydaelectronics.com/leds/round-leds/5mm-leds/led-5mm-yellow.html
$0.03 £0.023
LED 3MM BLUE
https://www.taydaelectronics.com/leds/round-leds/3mm-leds/led-3mm-blue-diffuse-lens.html
$0.02 £0.015
LED 5MM BLUE
https://www.taydaelectronics.com/leds/round-leds/5mm-leds/led-5mm-blue-lens.html
$0.03 £0.023
TRS Male to 1/4 Inch cables
Monoprice 8-Channel 1/4 Inch TRS Male to 1/4 Inch TRS Male Snake 26AWG Cable C/D - 1 Meter (3 Feet) with 8 Balanced Mono/Unbalanced Stereo Lines
https://www.amazon.com/gp/product/B00IACDT5I/
$16.98 £12.93
The price per cable works out to be $2.12 £1.61. 1 meter each, they come with extra shielding that binds them together that you can just remove. Different colors to boot.
This is a godsend caustic, I’ll finally be able to buy only the stuff i need and not 5000 of a single transistor! Thank you :slight_smile:
Im thinking about taking the stripboard layout Sam posts on patreon and doing full BOM for tayda or other places. I can post the BOMs on threads discussing the different builds, but im not sure how or if we should include the stripboard layouts. I totally understand if Sam wanted to restrict distribution. We wouldnt need to include the layout with the BOM, but i think it would keep things all nice and tidy.
@lookmumnocomputer, whats your thoughts?
Wow, great list!
10V might be a bit low for the 100µF capacitor as the typical power supply is +/-12V
Edit: also, you should not mix 74LSxx and 74HCxx chips, their input and output voltages are not completely compatible. I would recommend using 74HCxx, because their outputs are closer to the rails and they are compatible with the 4000 series.
hey caustic its fine!@ that would be cool!!! usually with the stripboard layouts they are public i’m not sure off the top of my head if there are any atm that aren’t only Patreon! so of course if you wanted to do that kind of stuff by all means go ahead :slight_smile:
THANK YOU for this list Caustic! I have been trying to source parts for Sam’s creations here in the US for the last 2 months. I have never done any of this before and am learning as I go. I am that person who took Sam’s “don’t be scared to try it” as a dare. So here I am. :slight_smile:
I am hoping that I could get some questions answered, please?
  1. I recently purchased these trim pots from someone on Ebay: https://www.oddwires.com/baoter-3296-100k-ohm-cermet-potentiometer-trimpot-trimmer-2-pack/
I mis-read the BOM and looked for the 10k, 20k, and 100k 3296 pots and not the 3296W pots. It looks like these should still work, but wanted to be sure just in case?
  1. For the 1222 Sam says to pick up “Eurorack power cables” with a link to the Thonk website. There’s quite a few options listed on that link page so I am wondering what to get? He also mentioned there’s a video to come on how to make them. Is there a parts list for the cables so I can get the parts I need while I am ordering everything else? I saw a few things that Caustic listed but wanted to make sure I have everything.
  2. Please be nice with this question as I am learning here. The BOM for the 1222 has the same link both for the 1nf and 10nf ceramic capacitors. It looks like the link for the 10nf is the incorrect one? What’s the correct link for the 1nf? I am asking because I thought I could just buy an assortment kit of ceramic disc capacitors that had all of the values I needed for Sam’s modules like 1nf, 10nf, 2n2, etc…, but I found there was a lot more to capacitors than just a value like voltage, tolerance, or things like Z5U vs X7R, etc… So now I feel like I cannot purchase an assortment kit for capacitors (ceramic or elecrolytic.) Am I wrong?
  3. Has anybody been able to source the 12 way rotary switch here in the US? The cheapest I can find it is on Ebay shipped from the UK for roughly $11. Rapid’s shipping rates to the US are ridiculous and start at $33 so that’s out. If someone has a US supplier and/or can get it cheaper than $11 please let me know. Here’s a link to the guy I found:
https://www.ebay.com/itm/Taiwan-Alpha-SR2611F011238F5BDNL-Break-Before-Make-Rotary-Switch-1-Pole-12-Way/362562612745
I found that this US Ebay shop has some of the best prices (that I could find) for the following: (They will also combine shipping.)
https://www.ebay.com/str/mdfly
3mm diffused LED’s - any color .02/each 5mm diffused LED's - any color .02/each
Resistors: 200 of a single value - $1.49 to $1.69
Thanks in advance for answers to any of these questions!
nicole
Eurorack cables: https://www.ebay.com/itm/Flat-Cable-10-Pin-pins-Wires-IDC-Ribbon-12ft-x-12mm-Wide-10-set-IDC-Connector/282084089830?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
capacitors: https://www.taydaelectronics.com/capacitors/ceramic-disc-capacitors.html
convert nf to pf or uf
https://www.digikey.com/en/resources/conversion-calculators/conversion-calculator-capacitance
This is the rotary switch I got, it could be wrong. https://www.taydaelectronics.com/rotary-switch-1-pole-12-position-alpha-sr2611f.html
This thing is great if you know you’re going to be making a lot of your own cables.
Not at all required, can do the same with a Vise, but the components it comes with plus the crimp tool is well worth the value (in my eyes)
Hey there @popflier!
  1. The style he uses in this is a “top adjustment” or “Vertical” Cermet pot 3296w. The product description in the link you gave looks right to me. I will link below the same from Tayda just in case, but you probably have ones that work already.
  2. To make your own, you need something that can clamp. I use a cheap vise, but I suppose careful application of force with other methods may work. Making the eurorack cables needs three components. The ribbon cable, the IDC socket, and the IDC socket connector. In the case of eurorack, its 16 pins (2x8). I print out a reference of the pin-out for the power bus to make sure i set everything up right. Find that below.
  3. A lot of us are still learning bud, myself included. That list above is just work I did that I didn’t want other to have to do as well. As @Riggidyboo points out, a capacitors capacitance can be represented in different units. Its like saying either 1 meter or 1000 mm. Means the same thing. You see this sometimes for reasons unknown to me. In this case, the BOM just listed the same link twice. No biggy! What i tend to do is buy the ceramic variety whenever i can, its cheaper and they dont have a polarity to get wrong (doesnt matter how you put it in). That said, the 1nf (nanofarad) caps in the BOM are the same as a 0.001uf (microfarad) cap in capacitance. I just print out a chart and reference it just in case (every time) also I label it on my baggies.
Whatcha need for Preset Trimmer Pots:
10K OHM TRIMMER POTENTIOMETER CERMET 25 TURNS 3296W
https://www.taydaelectronics.com/potentiometer-variable-resistors/cermet-potentiometers/3296w/10k-ohm-trimmer-potentiometer-cermet-25-turns-3296w.html
$0.28 / £0.21
100K OHM TRIMMER POTENTIOMETER CERMET 25 TURNS 3296W
https://www.taydaelectronics.com/potentiometer-variable-resistors/cermet-potentiometers/3296w/100k-ohm-trimmer-potentiometer-cermet-25-turns-3296w.html
$0.28 / £0.21
20K OHM TRIMMER POTENTIOMETER CERMET 25 TURNS 3296W
https://www.taydaelectronics.com/potentiometer-variable-resistors/cermet-potentiometers/3296w/20k-ohm-trimmer-potentiometer-cermet-25-turns-3296w.html
$0.28 / £0.21
Whatcha need for Capacitors:
What i did was just look up the values used in all of the projects and grab a couple hundred of them. Feel free and alter that plan by grabbing a little bit of a variety. Definitely use some more than others though, keep that in mind. Tayda doesnt care about small orders of individual components, the support there has told me that they strive to cater to the hobbyist.
1nf = 0.001uf
0.001UF 50V CERAMIC DISC CAPACITOR AEC BRAND - BEST PERFORMANCE
https://www.taydaelectronics.com/10-1nf-50v-ceramic-disc-capacitor.html
$0.03 / £0.023
10nf = 0.01uf
0.01UF 50V CERAMIC DISC CAPACITOR AEC BRAND - BEST PERFORMANCE
https://www.taydaelectronics.com/0-01uf-50v-80-20-ceramic-disc-capacitor.html
$0.03 / £0.023
100nf = 0.1uf
0.1UF 50V CERAMIC DISC CAPACITOR
https://www.taydaelectronics.com/10-x-0-1uf-50v-ceramic-disc-capacitor-pkg-of-10.html
$0.01 / £0.0076
10uf:
10UF 50V 105C RADIAL ELECTROLYTIC CAPACITOR 5X11MM
https://www.taydaelectronics.com/10uf-50v-105c-radial-electrolytic-capacitor-5x11mm.html
$0.02 / £0.015
Whatcha need for a eurorack cable:
Power bus:
$0.33 / £0.25
$0.30 / £0.23
16 CONDUCTOR AWG 28 FLAT RIBBON CABLE 1FT (30CM) (This is sold by the foot, be sure to get more than one foot!)
$0.33 / £0.25
Rotary Switch:
EDIT: As @Riggidyboo mentioned, the original link I posted was make before break, I think Sam mentioned you needed break before make in a build video if i recall.
ROTARY SWITCH 1 POLE 12 POSITION ALPHA SR2611F
$1.69 / £1.29
Also, feel free to buy from ebay if you find a better deal, but the costs for the 3mm led is the same at tayda. If you are buying from them anyway, you can also save with shipping costs. The resistors are more expensive at Tayda,
LED 3MM BLUE
$0.02 / £0.015
$1.49 / 200 = $‭0.00745‬ per resistor
$1.69 / 200 = $‭0.00845‬ per resistor
Compare that to the $0.012 / £0.0092 you pay at Tayda, with variable quantities! For ‭$0.00455 / £0.0035 more in price, you can add these to your cart with other components if you are buying from them. that eats the cost. Additionally, if you dont need 200pcs, you save the difference there too!
Lets say you dont need 200x 43K resistors, and you only need say like 15. It costs you ‭$0.18‬ / £0.14, not $1.49 / £1.14, a savings of $1.31 / £1.00!
@Caustic the rotary switch you linked
https://www.taydaelectronics.com/rotary-switch-1-pole-12-position-alpha-sr2511.html
is make before break, and the one I linked
is break before make.
Not sure if it matters for this application?
Aw snap, ill edit it. Good catch yo, thanks!
The connectors and headers can be had for stupid cheap in bulk on Amazon. For example these 50 for $6
https://www.amazon.com/dp/B07GGPM3CK/ref=cm_sw_r_cp_api_i_x2XkEb62JZD32
Right! I forgot that when i purchased these i got them from amazon (Tayda was out of stock at the time, but it worked out to be cheaper!). I’ll update my answer to use your link @ChristianBloch.
