Nonlinear Circuits Sloth Chaos packed tightly in a 10x16 board. If you want to build a slower version that uses considerably bigger and bulkier capacitors, you can mount those on the panel directly and use flying leads to the board. This thing is tiny so it can easily fit behind a 25mm panel and still have space for the larger capacitors.
