Hey! I want to make a few buffered mults using TL072 or TL074 with 3 or 4 outputs. Does anyone have a stripboard layout just floating around that would be conviniant to just post on here?
here’s, it’s with TL084 but you can switch with a TL074
Thanks alot, that should do it.
Are those 100K resistors or code-100 caps in the bottom corner?
i think it’s some 100 ohm resistor
Oh, right, I guess the caps are already green and labeled in that schematic. Wish this stuff had standard colors. Cheers.
When when i did mine, i thoguht it would be cool to do a buffered multiple and a mixer together. I think having more mults, and having mixer channel circuits elsewhere makes more sense.
Huge thanks, that is just perfect!
whaouu 20 jack socket !
a module that considerably reduces your jack stock in a record time
Someone know what the 10M resistors are for in @THOGRE stripboard.
They don’t exist in other schem/strip.
The 10M resistors pull the opamp inputs to ground if you leave an input open, but are large enough that they don’t have much impact on the signal.
Here is a layout that is 90% smaller if anyone wants to fit a multiple behind a 2.5cm panel and still have plenty of space.
