Hey guys, so after playing with a handful of designs I’ve noticed some differences here and there when it comes to how people design their decoupling and whatnot. I figure a picture is better than words:
Some designs call for 10Rs, some call for ferrite bead, some say either. Others nothing at all.
Schematics don’t really make it clear where abouts some of these components should be—i have learned a few things (placement of the IC decouples thanks @fredrik) but still have some questions
for the 100nf of IC (1&2) it would be better to put them apart, because there they go from +12 to GND and from -12 to GND (which besides are often added to the electrolytic cap of 10uf)
but for IC they go from pin + of IC to GND and from pin - from IC also to GND
10 ohm and capacitor near power header (this basically results in an RC low pass filter, but with a voltage drop over the resistor depending on the current). Usually somewhat pointless (the resistors, not necessarily the capacitors).
10 ohm without capacitors (either using them as fuses, expecting them to die if something’s shorted, or possibly just cargo culting, trying to do the above but forgetting how things work, see “power sins” here for more).
Ferrite beads (if done right, this can form an LC filter, but is usually cargo culting, see here).
Series diodes (using Schottky diodes with a low voltage drop, e,g, 1N58xx). Not a bad idea, if you don’t trust yourself (or are building production stuff for others who don’t trust themselves).
A slighly fancier polarity protection is to use MOSFET transistors; they’re available with extremely low drain-source resistance (tens of milliohms) so the drop will barely be noticeable even with higher power requirements.
EDIT: Even fancier is to use a dedicated supply controller (example) with the MOSFETs; they can protect against a whole lot of issues. Probably overkill for synth modules.
EDIT: Diodes between the rails and ground. This will short the supply if you hook it up backwards, under the assumption that the power supply is better prepared to deal with a short than the module is to deal with supply reversal (see the polyfuse link for an example).
EDIT: Rectifiers on the way in – using a few more diodes, you can simply route the voltages to the right rail, no matter how they’re connected. This allows the user to plug in the power either way. Drawback is more components and a higher voltage drop.
Bypass capacitors should be close to the power pins for the respective chips. Note that the bypass caps in your schematics are too tiny for most circuits; 0.1 uF (100 nF) is the usual size, some argue that with modern components 1 uF multilayer ceramics would make even more sense.
Whichever way you draw it they’re from the rail to ground, and drawing them in the schematic near the power supply is commonly done (and less distracting/cluttering/confusing than drawing them near the IC) but they do belong physically close to the IC.
Well, it is less clear, especially if you’re not aware of the conventions, but it’s often more practical that way (*). Ideally you’d have room to place everything where it should be, and draw out as many wires as possible so you don’t have to hunt for cryptic netlabels, but people are lazy
*) in textbooks, bypass caps are often not shown at all, so having them somewhere is a step forward in comparison
Yeah, but not using the pretty well standardized connector and having +12V instead of -12V on pin 1 is the best way to test how good your polarity reversal protection circuit really is.
Do we have the correct Symbol and Footprint for KiCad listed in the Kosmo Specs Thread?
But yes, as long as the pin designation of the footprint matches the symbol, it does not matter from a construction point of view. I have been tripped up by this on a header, not power though.
Sam often referes to the decoupling caps at the IC’s and leaving them out , same with the ferrite.
So is there any noticeable differenc with/without?
I have not designed anything from 100% scratch so far so gone from other peoples schematics, although where there are Decoupling CAPs I may have put them on the PCB in random places as I keep forgetting about their purpose.
I have seen a different variant for decoupling a tl074, where they put a single 100nf between +12V and -12V instead of the usual two 100nf between the each rail and GND. Is this also a viable option?
This was on some kassutronics project and he seems to know his stuff…
Sounds a bit unusual – usually the output load is relative to ground, and that path is what you want to keep clean. On the other hand, as you say kassutronics stuff is usually carefully designed. Do you remember what circuit it was?
EDIT: Checked his latest designs, and he’s still using that pattern. I’m not convinced; I think I’ll stick to the more regular way of doing things – it makes more sense if you look at the overall circuit, and if you can only afford one, you should probably stick it on one of the supply lines (which one depends on the opamp internals, but often the negative rail) instead of between two supply lines. But it’s not like a 100 nF ceramic is an expensive component (typically ≤ 1 cent each, also in small volumes)
