TheEJM3 Kosmo Builds
Hello all,
First time poster here - been lurking for a while. Not sure if I’m posting in the right spot. If I am, please point me in the right direction!
Not going to bore you all with a windy backstory so long story short: I’m building Sam’s modules on double-sided perfboards with Polycarbonate panels. Emailed Sam with some pics and he suggested I post them here.
Thanks for all of you posting here. You’ve helped me a ton on these builds - especially with the list of improvements to the VCO design. This is such a great place and an amazing community. Thank you!
On to the pics…
Case:
1222 VCO:
1184 Quad VCA:
1157 Mini ADSR:
Next up is the 1113 Filter.
Thank you all again for your invaluable info and support of one another.
I welcome any criticism :slight_smile:
Ed
New Hampshire
Welcome in the forum :slight_smile: , and very nice build !!!
Thanks Dud! Much appreciated!
case and modules look great !
Damn dude! Thats some good building!
Is the arduino in the 1222 backwards? Or is that for better trace routing?
I love the look of the clear poly’. Hmm makes me wonder about edge lit blank panels.
Welcome to the forum, you will be more than at home here =P
Thanks! The Arduino was mistakenly wired backwards. I got pin 1 of the socket facing the wrong way and didn’t notice until first power up. Oops!
I had the same thought about lighting… might be cool to route a small channel on the top/bottom of the case under the panels and throw a strip in them. Create a panel for case power & a CV w/ adjustable dc offset for panel lighting.
Looks amazing!
(shush discourse)
Nice! Total inspiration! Hey, where did you get the polycarb panels?
Thank you! I ordered 5, 12” x 12” x 1/8” squares from Amazon for $8.
I use a jigsaw with a very fine tooth metal blade to cut to size and standard drill bits to make the holes. Very easy to work with.
Here’s the link: Polycarbonate Plastic Sheet 12" X… https://www.amazon.com/dp/B07VVGL6GV?ref=ppx_pop_mob_ap_share
These polycarb panels might be the way to go!
OK for 1/4" jacks; 1/8" is probably too thick for typical 3.5 mm jacks, though…
They make thinner panels: VEX Robotics Polycarbonate & ABS Plastic Sheets - Robosource.net - Robosource.net
My link above is technically for 3mm, but they Americanized it for Amazon.
You could prob go a little thinner and get away with it as long as long as you have enough panel mounted components connected to a PCB for support. 3/32” / 2mm would be prime… not sure if 1/16” would be too flimsy.
1/8” / 3mm @ 20cm tall is a bit bendy at first, but stiffens right up when reinforced with the protoboard.
1113 Filter is done!
Added a circuit for the LED arrows and a white/pink noise generator based off of Electric Druid’s Noise2 chip.
The generator is fed into each the inputs if nothing is plugged into them and the white/pink noise can be selected with the knob between the white & pink LEDs.
There’s a second output next to the regular output for the noise to be used elsewhere in the synth.
I also switched out the 100ks on the inputs for 10ks and put a 10k trim pot in series to zero in on the point where the op amp gets overloaded. Works a treat and the hp/lp output match. Resonance is too low, but I couldn’t figure out how to get it higher.
LED arrow circuit:
Noise2 circuit:
This one was fun. Learned a ton. Wish I could figure out how to get more resonance…
Well, that’s a lot of LEDs! How much current do they draw?
Not sure. Can’t be that much, they are pretty dim. For comparison, the white and pink LEDs are connected to the 12v rail through a 22k.
I’ll try to rig up the multimeter to take read next time I take it out of the case.
Yeah, I guess not much, if I understand your schematic they’re in two groups in parallel after a transistor and 1k resistor from the +12 V rail. So roughly 10 mA for each group with each LED getting only about 0.3 mA.
That’s right and the gate of the transistor is connected to an AC signal half rectified so the LEDs are only on half the time. One set is on the positive side of the AC signal and the other is on the negative so both sides are never active at the same time. Looks really funky with a low note passing through it. Could cause seizures.
Duuuude, these all look so good!
Thank you, much appreciated!
