Hello again everyone! Sorry for the long time absence it has been some stressful times.
I just finished putting everything on the stripboard but now I have an issue: power. I was wondering what is the best way to power it and how to make the connections:
2 9v batteries
eurorack power source
power supply
My main goal still is to create a drone synth so I’ll build more of these and connect them to a mixer.
What transistors are you using? 2×9 V is a good choice when trying to get it to work, but if you want a lot of drones you probably want a 15-18 V DC supply so you don’t have to change batteries all the time. Eurorack’s 12 V is a bit low for most transistors, 2×12=24 V is a bit high but probably works; I think @analogoutput has experimented with that.
I’m using the SS9018. In the case of the power supply, where does it connect when combining like 7 OSC to a mixer? Right now I’m just trying to see if one works because it’s the first thing I’m still building do I think I’m going with the 2x9v and then swith to the power suppy when I’m creating the drone synth.
My question is what am I supposed to use to connect the cables from the stripboard to the batteries?
Check what size the jack is for your power supply. The one i linked to was for 2.1mm jacks. The one you linked to i think is 2.5mm, although it is hard for me to tell since i dont see any link to the datasheet or any identifiers that i can look up outside this site. You want to first know what your power supply’s barrel size is before buying these.
