Hey, I’m fairly new to modular synths and building diy components, I learned to build the Reverse avalanching oscillator (super simple osc) and it worked after a while on breadboard now soldering everything on a plate.
Now I was always powering the oscillator via 2, 9volt batteries in serie, but I want to connect it to a 10pin (or 16PIN? I think is overkill?) power cable so I can connect it to my eurorack power supply via a 10 pin to 16pin cable.
The 10 pin connector has 3 GND connections, 1 +12v and 1 -12v, what is the difference between the Ground and the -12v? and where do I connect the + and - I connected earlier to the batteries? I’m confused can someone clear things up for me??
Voltages are measured relative to ground, so +12 V is 12 volts above ground and -12 V is 12 volts below ground. The voltage difference from +12 V to -12 V is 24 V.
If you were using 2 9 V batteries in series presumably that’s because you’re using a transistor that needs more than 12 V to oscillate. But you should be able to connect what was connected to battery + to +12 V and battery - to -12 V. That will give a total of 24 V across the transistor+LED, versus your previous 18 V; should work but might behave a little differently than it did.
However if you have an output jack whose sleeve terminal formerly was also connected to battery - it should now be connected to ground.
Wow, thank you so much for a fast answer! You’re the man.
However, it’s not entirely clear because my battery- is the same as my ground in my circuit, wouldn’t it also work to just connect the ground to ground and +12 to battery+ ?
There is just one thing I don’t understand here and that is that I don’t know where to connect my audio output jack now, because I don’t have a separate ground and -12v in my circuit? I’m still a bit confused, using exactly this circuit:
