Truely nice color scheme!
Thanks! I am going to eventually publish the design. I think it would be very handy for folks building their own set up. Itâs also sized to be able to fit Eurorack modules. I might eventually do a Kosmo compatible version, too.
Is that clock online somewhere?
Itâs based off this: Modular synth clock module DIY ARDUINO, "SM Tik-Tak" - Arduino Project Hub
I switched the timing pot for a rotary encoder and added the OLED display. It defaults to 120BPM. A short press on the encoder doubles the BPM and a long press resets it 120.
Here is my modified code, sorry I didnât comment it very well: TM_TIK-TAK_-_MOD03.zip - Google Drive
Nice, I was thinking of doing something fairly similar based off the same thing! Thanks for sharing.
Made an enclosure for my arduinoboy pro. Officially the first thing i designed myself for my 3d printer. Dang its awesome not having this thing as a loose pcb. Even remembered to put in a pushbutton and holes for seein leds.
Nice colours, I love the variety!
I (almost) finished the polysynth today. It has all the functionality you see on front except switching the VCF to bandpass output. The multiplexer which is switching between LP/BP is clipping the signal and I need to figure out a fix for this. It took me almost a year to finish the project, some ups and downs, I needed to redo some of the PCBs but overall a great outcome.
Here is some small example that I recorded:
I will try to make a small video in the next couple of days but I never did cutting and stuff like that. Letâs see.
Good work !
a little surprised that there is no VCA
@Dud the VCA is controlled by ADSR-2, there is no other functionality besides that. Thatâs why there is no VCA section on the front panel.
Aaah ok, I was telling myself that there had to be a trick somewhere
These are the 1st versions of Decade(nt)-Count-O-Matic (based on a CD4017) and Bin(ary)-Count-O-Matic (based on a CD4040)
Both consist of 2 PCBs combined via a pin header and fitting connector:
The smaller PCB contains the logic, the bigger one the IO-connectors and LEDs.
I tried doing that but mine still doesnât work. I gave up on it ever working after that.
Is the chorus schematic your own or did you use an existing schematic?
Itâs the gligli Juno 60 chorus clone: GitHub - gligli/juno-chorus-clone: Roland Juno-60 chorus board clone
I updated it a bit so it can be sent to JLC. Tell me if youâre interested in that, I will push my fork to GitHub.
Oh, that is a different version than the chorus I have. I havenât done pcbs on the one I have as there seemed to be a few errors that someone found and posted about on a forum (modwiggler maybe?) This is the schematic for the one I have below. Iâd like to take a look at yours if you donât mind? Thanks for offering to push your fork to GitHub.
Here is the schematics of the Gligli chorus. It looks pretty much the same to me except that the parameters can be adjusted by pots.
@popflier I uploaded my changes and gerber files to GitHub - polykit/juno-chorus-clone: Roland Juno-60 chorus board clone
I think it was mainly the missing paste layer.
Very nice, i like a lot the natural wood style
