@Jos @TimMJN Thank you for the responses, it is as simple as I expected, self-certification
Today assembling a Dual AD/AR
and also put my power in the case, with switch and the diy bus board.
I prefer to finish my panel and assembling module (only 4) before testing all, but just testing my Twin Drummer quickly
I installed it with the others drum modules in my 2nd case (instead of an cem VCO which will go into the new one)
all work fine, i’m very happy because the circuit was not easy to build
here a short demo triggered by the Big Button
Finished up one of 2 CGS66 - this one is running half-wave rectification just to get by until I find proper 18-0-18 center tapped transformers. (If anyone has a link for one that doesn’t have 22 dollar shipping, that’d be nice)
Trimmed for a perfect ±15v
the sound of the twin drum is so great ! this is from the design of LMNC with the cd4011? what modification have you make to add decay controls ? (I don’t remember that it was on the schematic, or I’m wrong ?)
Yes it’s with the CD4011A
and i’ve not add anythings, just adapted the schematic on stripboard, all is here
Boards for my mult arrived today, also the boards for the LMNC quad vca, but that is tomorrow’s project.
Today was a Multi day
@Dud, may I ask, why do you use a switch on your mults, rather than normalizing the input jacks?
you mean use the switch of the jack ?
yes, if you only plug in 1 input the others get the same signal.
I do that by reflex I think (I’ve always done them that way), but actually that would be better, more possibilities
I could still do it, but … to be continued
Here’s an update on my new oscillator module. I have called it the 4010666 due to is using the 40106 ic.
Very nice(discourse has throttled my likes)
What happened to the little troll?
don’t worry ! behing the paper (surely he’s sleeping)
Worn out by all the work you put him through
