Scored a 1613 on eBay so I thought I’d make some cables for it!
With the suggestion of 2.1mm Barrels from @WesleyV - I came up with these
After modifying the 8 step arduino sequencer, I tackled my 1st APC CD4017 sequencer with LFO.
It was not very clean inside !
I modified the External Clock IN which was a bit rough: now it works fine with the modular. And I also added a Reset button for synchronization.
I will surely also look at my other old DIY sequencer (a 16 step gate, and a APC/CD40106, 8 step with lots of different LFOs, VCF) if I can update them
I started working on a double envelope follower. These will be the oscillators for the sampling logic, the reset transistors and the 2 gate outputs:
6 x analog sample and hold and 2 x mixer bits of the dual envelope follower I’m building:
and front panel:
A little vid of my 1rst Sequencer APC with the recent External Clock INPUT add.
Here triggering by the clock divider of my modular
I also added another switch to mute the internal clock (555) when I use an external one, because the impulses of the 555 caused the regularity of the external clock to vary slightly and occasionally.
A DPDT would have been better than 2 switches, but I didn’t have one.
The most important is that it works ![]()
Wow, that must have been a difficult problem to solve. How did you find out that that was the case?
Wahou Nice job, I have a sparkfun tsunami too and I would to mod it for my modular. If you have more informations its could be cool
what is the maximum voltage to triggering a wave ? Thank you
In fact not really, in first a put also a gnd to my panel
and after with an external clock, with the rate pot of the internal clock adjust to very speed sometime it jump a step (or 2) , more detectable than when it was slow, so I tried to cut it squarely and it was good.
Il envoi du pâté ton apc / séquenceur
Hey there are some of my last 9v circuits for a poor man’s modular project
The dual Shoosh VCA from “damienclarke.me/effects-pedals/posts/building-a-vactrol-vca/”
Some passives LPG and one active LPG inspired by the colourwah pedal (beavisaudio)
Three dirty and messy vcf inspired by Q&D from Tim Escobedo
A utility module with gate to trig converters and dual delayed pulse/gate
A 9v diode ladder filter version by Tom Gamble from EFM
If you want more informations or schematics tell to me !!
I dont know if its the good place for this post…
An infrared trigger/gate generator, the module is fun and very fast to triggering a lot of things !!
More informations here =>
https://www.instagram.com/p/CHBdwg9h4jr/?igshid=16kau6u5m6xqa
https://www.instagram.com/p/CG-k1r3KnuY/?igshid=10pgkxpjjhpnw
Sorry, Im going to make a new diy page for all the people who don’t have an instabitch account ! Work in progress…
Wow, you have been busy!
I was at home for over a year, indeed I spent whole days in the cables and burnt circuits…
I’m working on a double board design and thought I’d try a hinge to link them together. In this way I can sort of sandwich them behind the front panel and still easily access the electronics when opening the hinge e.g. for debugging a problem.
My intuition tells me this could work. We’ll see whether it does.
Nice idea !!
your design is perfect and ingenious !!
Finally! My music shelf is done!
Now I need to complete that case… Still waiting for my Tayda order to come…
And I made a “drawer” for my beatstep, really nice!
Very nice installation !
Someone gave me some plywood this morning, I also got some wood elsewhere.
Yeah I’ll be able to finally start my case this afternoon !
Génial ! Merci pour les liens
et je te retourne le compliment !!
