Inspired by another of @HAGIWO’s builds, I’m slowly working on something like the AD9833-based LFO design. It won’t be Eurorack or Kosmo format, it’ll be Whatever format because I’m just ambling along, doing my own thing, as you can see…
I’ve got a mixer to go in there once I’ve printed a panel for it and will fill gaps with things like buffered multis and ground loop isolators. Might even label some things somewhere along the way!
I havent had to use any interrupts with my encoders either. If I were to use an IO expander like an MCP23017, then it might be needed, but I have had no problems without them.
I was driving 2 SSD1306 screens as well, so I think it’s overkill.
Today I rewired the MS20 filter mentioned yesterday so that it fits on the panel. Tomorrow just stick on the foil and then it will be time again to play with the built things
I hope my Tayda order arrives after an endlessly long wait so that I can finally finish building my midi thru box
Had a very productive day. I built a mixer (second from left) and added pulse-width support to my VCO (left). This is all I have built so far. The modules on the right are my output module and a passive attenuator.
I just ordered a 84HP 6U eurorack frame so I have plenty of space to fill. First I’m going to make a quick stand for it and later work on a proper case.
The only thing I’m unsure about is the use of 2mm MDF for my front-panels. I’ve designed it and ordered it to be laser cut at a local company. It is a bit bendy and my jack sockets sometimes don’t cooperate, so there is a risk of breaking the panels : I would really like to go for a wood-like look, but my jack sockets don’t allow to be mounted on thick wood (2.5mm max I’d say). Any tips would be appreciated.
which of course is exactly where the stresses are largest, so maybe you increase the likelihood of breaking the wood with insertion force, but at least the panel will bend less.
You could try gluing reinforcing strips along the length of the panels where there’s space. Some epoxy and a length of a stiff rod (could be metal, could be dowel) would help a lot. I’ve been 3D printing my panels to about 1.4mm but then having 5mm ridges to provide the extra rigidity which is pretty much the same situation.
Note that the 3340 sync inputs are slightly weird. The original CEM3340 datasheet has a discussion and some sample schematics, if you want more “normal” sync inputs, see here:
I made another (simple) mixer. Its a double one where one of them provides a sum only and the other a sum and a negative sum of their respective input signals:
This is the drilling template, but this is what the panel will look like when it’s finished. I did it like @Dud and also built in large and small jack sockets.
And I have to announce something. I’m officially in love! This is my first module with large jack sockets and it just feels sooo much more correct than small cables! About 5 modules left, then my rack is full anyway, then I can finally start with KOSMO - in this case bigger is simply better.
