First stripboard layout, looking for feedback
Hello,
I’ve built a few modules, but this is the first time i’m attempting my own stripboard version.
This is Moritz Klein’s ADSR
If someone could take a look that would be awesome!
It is not clear that the 100k resistor is connecting pins two and six to the positive rail. It seems as though the 100K resistor just has both legs soldered to the positive rail. It seems like you should tie pins 2 and 6 together and jump the 100K resistor from pin 6 to the positive rail, but since you don’t have any other connections to the positive rail past that point on the strip board you could just put a break between the legs of the resistor. That would be easier I think as far as a modification to the layout goes.
Everything else looks ok to me. Oh, also, hello and welcome! :robot:
Thank you so much,
I’ve made the changes, I will have another look at it and then probably try and build it.
There is no indication of any track breaks under the TL074.
