The circuit first attenuates the synth signal going in to guitar level, sends to pedal, returns from effects pedal, and then gets amplified back to synth level.
If you plugged your synth straight into guitar pedal it might do bad things, although the 3 old pedals I have seem to tolerate a raw signal from my Kosmo just fine
Alright so you tell me I can do this ? And it would work ? I’d like to keep the “from synth” and “to Fx” in case I decide to use only a stomp box pedal
If your guitar amp has an output jack I would just send my guitar thru the amp first and into the splashback, making sure to start at low gain and turning up slowly
I think it would be easier, the stomp adapter would work (if the design actually works for you) but it does two jobs when you really only need the boost/amp part of the circuit; You just need guitar to synth
That would be a really good alternative if I’m tight on schedule But eventually (like in a month) I’ll have to build the complete basic modules of a synthesizer (VCO,VCA, blabla). So I’ll try to build an amplifier for my guitar signal anyway. I found the boost schematics as you said (second box) And I might have some questions about it eventually haha
Hi !
So I’m trying to make a circuit to boost my guitar to synth level. @Ctorp showed me this schematic. I want to keep the boost section only. But the main problem is that I don’t know how. I was wondering :
-is it necessary to keep the portion circled in red (the offset section) ? can I delete it and plug the input right before R4 ?
-Is invertinput important for boost ?
-Also, can I cut the link between boost and attenuvert section to plug the output ?
-Is there a chip with less legs that does the same job as TL074/72 ? Because I don’t think I will need this many legs. (like 1,2,3,4,5 that’s it)
-Should I replace the 6 pins header (J6) by a 4 pins header?
