Offset Boost Attenuvert, a utility module that offsets (+/-6v) then Boosts (1-10x increase) and attenuverts (2 outputs with separate attenuverters)
it also has a invert and none invert input that can be mixed together.
initially made for the sensors in the power glove, but also works well for bunch of other stuff, distortion/weird modulating thingy/making the 1114 sound different etc.
ok this might be the first module i need a manual for
please post a video with some application examples. is it for integrating low output things into modular? like getting cv from a guitar pickup or something?
ha indeed ill be doing a vid on both this and the filter within the next few days! it can be used for that as it has a circuit that can boost up to 10 times so yeah!! its not just for low voltage stuff, I just had the need for something like this so built it! the uses are still up in the air but ill think of a few for a vid definitely
I thought for one joyous moment that emoji had been turned off. It’s an infestation in my opinion. Even my Android keyboard has pages and pages of pointless pictograms that get in the way just when I’m trying to write something.
right sorted, also realised the bill of materials of the filter grr has a couple of resistor values in separate fields. which is just a bit confusing so will fix now too
On the site it says ‘you can use it to boost a guitar or a piezo mic going into the modular’. Does this mean you can just plug a guitar straight into the module, or is it taking the signal from an amp?
