I’m now picturing a stoic Scotsman with a soldering iron suddenly slapping a board on the table with ninja-like speed, then carrying on soldering like nothing had happened.
I listed some options earlier in this thread:
So far so good. They were what I had on hand when I started, and are cheap. I can see them failing at some point, but are cheap and easy to replace when/if they do. For my diy non-PCs modules they’ve been working great so far. If I was performing professionally I probably wouldn’t use them. But as a hobbyist…I’m fine with them.
Stoic Scots just take a dram and spit the blocked solder out. Lovely to see ivor Cutler!
I have the solder sucker my dumbassery requires it. It does the business.
I’ve been a lot more relaxed about needing to desolder since I got the Engineer solder sucker.
Same. I’ve posted in this thread enough to invest in one.
That will work for one pad, but I really advocate for braid on hand in case you need to clean something like a chip header. Those are practically impossible without some braid to suck it up, and it’s bound to happen at some point.
The braid is my savior.
I hated braid…until I tried the MG Super Wick. That stuff is like magic. Now I prefer braid over the sucker in most situations. The other trick is using the right size braid. The “yellow” #442 works best for me on most things…but I also keep the larger green #425 on hand for larger components.
I after many attempts for messing up clearances. Tend too make a position template out of a bit of plywood for placement then position it is place clamp it down and drill. Then after I completed it I use the aluminum for a template if I am making more then one.
When you need too make it very tight.
this is my mixer module
It turns out pretty funky !
When you discover that, like a complete rookie, you got a variable resistor connected backwards on your PCB layout, you can toss out your module and try again, sacrificing eight 9mm B100ks in the process, or you can bodge.
yep, got the t-shirt for that one
Whoops, got a little aggressive with the flush cuts there…
But a little bit of cut off lead and careful soldering:
Rescued!
So uh… I finished this filter… and it was REALLY quiet… no smoke tho…
I used BC547’s and 557’s… the sheet calls for 2N3904’s and 3906’s…
Does anyone see what I did wrong here… lol
No sweat, that’s only, what, eighteen wait nineteen transistors you need to re-do?
wanna know what makes it even moar dumb…
I forgot I had ordered 2n3904’s and 2n3906’s and they’re sitting in my mailbox… lol
