A beginner's guide to the components of a modular synthesizer
10 - BUFFERED MULTIPLE
Buffered Multiple is a module that allows you to multiply a signal.
One enter signal and you have the same signal to severals out.
Here 1 input for 4 output, and again the same things down 1 input for 4 output.
Indicator Led : to indicate if the enter signal is positive or negative
Red = positive and Green = negative
You can for example multiply a VCO to have many voices
You can multiply a Clock signal to send the same clock to several modules.
Very used, multiply a Envelope to send the same Env. to the VCF and also to the VCA
:slight_smile:
