9 - 2399 3x SPLASHBACK DELAY :
The delay is a module to make some echo to your sound. Internally there are three delay units. Each one takes an input signal, delays it for some amount of time, and sends out a mix of the original (“dry”) signal and the delayed (“wet”) signal. The output is also fed back into the input so there are multiple “echoes”.
INPUT : enter for the signal
OUTPUT : the out of the module
ON/OFF SWITCH : when it is OFF the signal passes through without being affected by the module, and when ON the module operates
(an LED just above the switch indicates its state)
CV IN : with an external signal you can control the TIME from another module.
CV ATTENUATOR : controls how much the CV IN affects TIME
MIX 1 / 2 / 3 : adjusts the intensity level of each delay
HI/LOW SWITCH : allows you to choose whether to apply a low pass filter to the output of the effect
SPLASHBACK 1/2/3 : adjusts the feedback level of each delay
TIME: regulates the basic delay time for all three delay units
TIME 2/3 : regulates the additional delay time (above TIME) for the second and third delay units
