#2001 keyboard sequencer
Perhaps you can guide me on this:
When I attempt to upload the code onto an Arduino I get an error code during the compile and it doesn’t complete.
Sam’s 2.2 code compiled and loaded for me after it created it’s directory tree.
I’m pretty sure it’s something I’m missing here.
What error are you getting?
Hmm, I’m not sure what compilation errors you might be getting.
Can you try creating a new sketch, and the copy/paste the code directly from https://raw.githubusercontent.com/criggs/lmnc-2001-keyboard-sequencer/refs/heads/main/2001_KEYBOARD_SEQUENCER/2001_KEYBOARD_SEQUENCER.ino
Make sure you have Arduino Nano selected for the board type. The Checkmark/Verify icon should compile the code without uploading it. If that works, then your issue might be related to uploading with the right bootloader. Some nanos require you to select the ‘Old’ bootloader instead of the default one.
Thanks for your reply and input!
Reporting back: compiled correctly this time - I was careful to place the INO in a directory with the specific name exactly as it is on GitHub
Some of this VooDoo I insist is quirky goings on within my Laptop and Windows 11 because things in Arduino IDE application and Arduino NANO hardware do NOT behave consistently session to session. So NOT YOUR PROBLEM.
As it stands currently I have a successful upload now so I’m going to go play with it.
Some oddball /310 error related possibly to directory tree or something - my laptop is weird.
When working with other people’s code I have found it useful to code on a fresh virtual machine I dedicate to that one build or board. It’s overkill but makes debugging a lot simpler.
I wonder if someone will correct the BOM, had to make another order with Thonk for another proxy switch, most inconvenient, and totally unnecessary. Boo Hoo.
I have my eye on this one. Are there plans for a restock @lookmumnocomputer
it is unclear if legacy modules come back. sometimes they do, even after being unavailable for a long time. I am hoping for the retun of #1157 mini adsr and #4710 Safety valve. it depends on the creator. i’d say you got a 50/50 chance and they are probably not restocked while our local hero is bussy preparing for his big day on ESC.
(mashed together historic screenshots from the lmnc shop i keep for refference)
turnover is probably relativly low and holding stock with 100% will cost money. Many modules were probbaly limited run to facilitate Sams own need with a numberof spares for retail.
There may be a redurgance of interest in Kosmo after the Contest and that may elevate the sales on module kits. Who knows.
I’ve been hoping for some restocks too, but obviously he’s got a lot going on right now. (kicking myself for not getting an extra OSC expander…)
However.. the Kosmo format building community is growing and there’s a whole wiki of open source projects:
