1157 Mini ADSR Bill of Materials (Tayda Edition . . . lol)
All parts can be sourced from Tayda with the exception of SW2 - (ON)-off-ON Toggle Switch for the ADSR Trigger.
These can be easily found on Ebay.
Tayda is almost always out of B10k 9mm Potentiometers, so I also included a link to Modular Addict.
1: 2N3904
Designator: Q2,Q1,Q3
Qty: 3
2:100n (0.1uf) Ceramic Disc Capacitor
Designator: C1, C2, C3, C4, C5, C6, C7, C8
Qty: 8
3: 10uf Electrolytic Capacitor
Designator: C9, C10, C11
Qty: 3
4: 5mm LED’s
Designator: D1, D3
Qty:2
5: 1N4148
Designator: D2
Qty: 1
6: 10-Pin Power Connector (Eurorack Power Connector)
Designator: J6
Qty: 1
7: Ferrite Bead (or 10R Resistor)
Designator: FB1, FB2
Qty: 2
8: 1k Ohm Metal Film Resistor
Designator: R20, R3, R6, R19
Qty: 4
9: 10k Ohm Metal Film Resistor
Designator: R1, R2, R13, R14
Qty: 4
10: 100k Ohm Metal Film Resistor
Designator: R8, R10, R12, R15, R18
Qty: 5
11: 47k Ohm Metal Film Resistor
Designator: R9
Qty: 1
12: 9mm Vertical Potentiometer - B10k (Alternative Source: Modular Addict)
Designator: RV1, RV2, RV3, RV4, RV5
Qty: 5
13: (ON)-off-ON SPDT Toggle Switch (ebay link)
Designator: SW2
Qty: 1
14: On-Off-On SPDT Toggle Switch
Designator: SW1
Qty:1
15: TL072 Dual OpAmp
Designator: U2
Qty: 1
16: 7805 5v Voltage Regulator
Designator: U3
Qty: 1
17: Electric Druid ENVGEN8 (Included with PCB/Panel Kit)
Designator: U1
Qty: 1
18: 14-Pin DIP Socket
Designator: U1
Qty: 1
19: 8-Pin DIP Socket
Designator: U2
Qty: 1
20: 6.35mm (1/4") Box Style Jack Sockets
Designator: J1, J2, J3, J4, J5
Qty: 5
21: 24mm Aluminum Knobs
Qty: 5
Not Required: (Can be used for the Jack Sockets - otherwise just solder the wires directly to the PCB)
Happy Building!
