Hiya, I read a while ago that 100k draws less current than 470k, is this true. As i’m building a new lunetta type machine I have mostly 470k that I bought from Maplin,when they were having their closing down sale. I’m using a 9v battery to power this going into a 5v regulator, just worried about using up the battery power with all those 470k pots (10 in total). Will that be an issue? I have a few 100k so may use those too. Many thanks.
No. Ohm’s law: I = V/R. Larger resistance, smaller current.
If you’re dropping 5 V across a 470k pot, I = 5/470k = 11 µA. 10 such pots is 110 µA = 0.11 mA. Typical 9 V alkaline batteries have a capacity of about 550 mAh, so if the pots were the only thing drawing current:
t = 550 / 0.11 = 5000 hours
That assumes you’re using the pots as attenuators and that current out of the wiper is negligible. If they’re used as variable resistors, R will be smaller (down to 0 Ω, though there should be a fixed resistor in series to limit the current) and the current will be higher.
But even then, if R is typically ~ 100k, I = 0.5 mA and 550 / .5 = 1100 hours.
Presumably your device’s active components (ICs, transistors) will be drawing significantly more current than that and the pots will not be significant in how long the battery lasts.
Again you’ve explained it very well, thanks. Yes I’m using the pots for both attenuators and variable resistors. I thought the same when you said the IC’s, transistors will be drawing more current than the pots. It’s just nice to have some backed up info from a well learned source as yourself, thanks again.
