Verified Stripboard Layouts!
Mine were all fine. Code was whacky for me
What I mean is people need to check what the code says to connect to which pins go where. They are labeled.
Just finished my System 100 dual LFO.
happen to have this same thing for the Monotribe? lol.
I don’t, but seems to be possible.
Roland TB-303 sequencing Korg Monotribe using CV Gate breakout box
more
I made a small edit to this…
I made this layout from a schematic I found on Extralife’s youtube page. If you have a monotron delay, and want pitch and gate from external sequencer, it works quite well. Probably works on a Duo as well. If you pop the monotron open, the solder points are labeled on the pcb. Pretty easy.
Bump!!! I need a project! Post your favourite successful stripboard lockdown layuouts!!
I’d be VERY careful when soldering to the korg boards, the solder pads come unstuck very easily, I killed my Monotron by accident whilst building this
and trying to find another original Monotron is like searching for The Holy Grail !!! :wink: :+1:
“You mean like” (pulls open desk drawer) (finds a lone monotron DL, no trace of the other one) “never mind”
(I’m sure it’s somewhere)
I have the Duo and Delay, (and a F*cked MONO :thinking: :upside_down_face:) I also have the Kit for the Delay to Eurorack module but a bit apprehensive about tackling it! There isn’t a kit yet for the DUO, apparently it’s in the pipeline but the whole layout of the Duo is completely different and the board hasn’t got much space on it :upside_down_face: :crazy_face:
Graphite glue and similar conductive adhesives are great for Modding and fixing traces when you don’t want to take an iron to a machine soldered PCB. Also soldering a wire to a small washer or metal leg and gluing it or taping it to the point you want. Planning to modify my Korg delay with a sheet of thin card matching the the internals with copper tape pads where the touch points are. (Will it work? Dunno but it won’t break it)
Enjoy
Did a few mods on the Delay.were pretty straight forward. Double lfo time button, skew, cv pitch and gate, and ldr control. Even made a fancy stand.
thanks for that! :pray: :+1: :sunglasses:
i add the resonance mod on the filter of mine
Just built one of these. Works very well! Sub Oscillator
Simple Hi hats & snare!
https://youtu.be/hcrUC7-FUcQ
Nice, is that two behind one panel?
Your own design?
i have made it with only the high hat
i think it’s with schematic
good job !
ps: you can make a space after your link to incorpored your vid
Not my design, but yep, 2 of em.
SNARE/TOM from : “Unauthorised Service”
