The effects section
Hi folks, which effects do you use? Why? And, above all, which ones did you make yourself? I ask you to post your verified layouts here.
many Greetings
THOGRE
If it’s about FX module, i have made a cheap PT2399 delay, a Dual Distortion Unit, the Safety Valve Dist, and not an FX module but very usefull for it : a Dual Stomp Box Adaptater.
I almost finished the DSP FX100 and also plan to add a Spring Reverb module with Tank (Tombola) later.
If you mean guitar, I am fiddling with a Celeste Chorus (MN3007) and a PedalPCB NuDrive as I was intrigued by the 6N1 tube from Korg.
But I constantly manage to solder wrong potentiometer in wrong place and there’s a 220n cap I cannot squeeze into place.
When I run out of space for caps I use smd components. Fiddly but fun.
I always end up looking forever for that one value of resistor or capacitor I don’t have until I remember to look in my SMD sample books. Pro tip.
