as far as I understand, pro-desks use LOG pots to compensate for the progression on the decibel scale and provide a closer to linear control of the signal amplitude.
The Simple Mixer states LIN pots.
Am i misunderstanding, or would it be better with LOG pots?
Keep track of which is which though-the logarithmic progression works for audio signal level, but not so good for oscillators, envelope generation, and many kinds of attenuation.
Yeah, they’re usually marked A for Audio. They’re neither audio (as in human hearing response curves) nor log, but rather piecewise linear, but that’s electronics conventions for you.
Note the V curve, btw – the alps potentiometers I got that graph from use a mostly linear curve for their volume control, not the textbook “log” curve. See here for a few more variants.
Module A-138 is a four channel mixer, which can be used with either control voltages or audio signals. /…/
A-138 a: potentiometers with linear response, so especially suitable for control voltage mixing.
A-138 b: potentiometers with logarithmic response, so especially suitable for audio signal mixing.
