I’m doing a repair job on an old Japanese spring reverb. The main mix pot is really janky so I opened it up thinking I could replace it, but it’s something I’ve never seen before. There are the normal three pints at the bottom, but it looks like there’s a small board integrated on the top side with a wire coming out.
Anybody have a clue what this could be? Doubt I’ll be able to find an exact replacement, but maybe I could figure out a bodge if I knew what this output (input?) was.
Are these odd pots illuminated on the face?
You got a lot of ‘board’ wired on to stop pots cracking the nice plastic face. A way of mounting lug pots on a breadboard. It would be grounded like a case.
Have you a schematic?
I also found Potentiometer with four terminals “used to alter the resistance curve for special applications”.
Perhaps you can bung in any 50k pot to get the unit working ignoring the yellow wire, so not the original taper. Best of luck.
