Hey guys,
happy to be here and happy to find this board and i learned something already in terms of electronics and eurorack. Close to 20 years ago i was on a school for basic electronics but down the road i switched to graphic design and now UX Design. I am on eurorack since 3 years now and now i want to tackle my first DIY Module. And i need a litte help. A lot of what i have learned is gone. And i hope you guys are able to help me. So tips on youtube clips and sort of are relly helpful.
I currently working on a 1U, 126hp module for my suitcase. It will be a bus/buffered mult module kinda inspired by the make noise cv bus case. My concept will also include a sort of patchbay for my external gear which will be just a “connection” to my external gear and is centered within the modules frontplate. So therefore i don’t need any help here.
I have watched several post on this board and copy out some concepts and put them together for buffered mults and LED to indicate what is currently running. What i have created might be working but it can also be total idiotic crap. Like i mentioned i have no clue what i am doing and my knowledge is 20 years old, never used and was also just basic of the basic knowledge.
Check Frontpanel Layout on Screenshot
In the center you see my external gear patchings. On the left and right side you see my concept of the Bus / Buffered Mult. I will be 4 times my bus and mult solution. We will discuss just one since they will work the same.
Check the basic schamtic section of the screenshot.
There are three different conditions that the Bus/Mult will offern:
1.Just a Buffered Mult
In The First configuration everything is acting like a 1X3 buffered Mult on each side.
2. A Bus to Right
A input on the left will be bussed to the right, everything else will be a buffered mult
3. A Bus to the Right to Mult
A input on the left will be bussed to the right and mult.
One thing to note. Several Inputs will later act as output or via versa. So above you see the behaviour i have in mind. Check the inputs “CV in” vs. “CV out”. Also on the left you will see LED indicator which indicating the current setup of the module.
So based on that concept and my 20 year old knowledge and the diving through this board i came up with this electronic schematic. I have several questions and i guess you have the answers. So it would be great if you can pin point me to certain erros or give me a better schematic. Check the schamtics on the screenshot.
A little explaination on that schmatic since i use no curcuit app or something. The red dotted lines are relais route to switches. You will see if they are on or off. I have no clue which type of diodes i need to use. All other parts are based on this post i found here
So here are some question:
- Do i understand the concept of diodes correctly and do you have any reccomondations what type to use?
- What to do with open switches? Do they need an resistor or something? To ground? (Check Screenshot)
- Is there a better way for using relais. Are they practical for usage? Is there something better?
- If you check the post above where i get a lot of my concept there is this and i have no idea what this is but i see it is realated to power supply?(Check Screenshot)
- What about those oben jack inputs? Check input 2. (Check Screenshot)
