A few hours later… I still have to solder in 2 transistors and 2 resistors, which are still in the package at my sister’s home. So I can’t do that until tomorrow. The next step is to see how long the cables from the potentiometers to the panel have to be.
Hey, you makin sure that the ground buss etc is broken before it gets to the chip?
THX, of course it is !
By the way, that’s Sam’s layout, just with the Eurorack Power Bus thing. On the webpage the resolution is not that good and you cannot zoom, here you can
I started a new project, and I’m not saying what it is yet. The prototype is working, so much I will say. But I thought I’d add a teaser just for fun:
Hardware’s together, but I don’t intend to deal with software at this point in the evening.
Edit: Yikes, the OLED connections are wrong. Gonna have to kludge something.
Hm. Here’s the original designer’s OLED:
and here’s mine:
I detect a subtle difference.
That’s mean ! You can’t even tell what’s on the IC.
Unlucky… I have seen differences between different STYLES of display, but makig the same style with different pin layouts is unusual… is the driver the same?
wow that would drive me bonkers…
Appears to be entirely compatible aside from the pin order.
Wonderful!!
I got some that were SPI / I2c , but you had to change SMD’s to get I2C to work ( I could not ) the seller could not advise any better and just refunded. And I got some I2C only ones like one set of your
I managed to only get 2 addresses. 0x3C and 0x3D
It would be nicer if the ones i got just had solder jumpers, but i just needed 2 addresses so it was fine for me.
(with some M-F jumpers to get the pin order right)
Apparently I bought a half dozen 4051s back about seven years ago and then never used any of them, until now.
I have to use the i2C MUX for the Sequencer as the displays are fixed address and there is 4 ( or even 5 if the design changes slightly.)
No Need to Swear! ![]()
That looks ace, nice use of the yellow topped screen. ![]()
It is! (Not my design so I can say that.)
If you look on the back, mine had a SMD resistor that i took off to get a different address. I messed 2 of mine up doing this so only attempt if you dont suck or if applicable.
ARM Cortex-M7 MCU, High fidelity AKM stereo audio codec with up to 24-bit 192kHz, 64MB of SDRAM, and 8MB of flash memory, furthermore a TL074 used for buffering.
I can get t-shirts for
“I killed my I2C display trying to re-address them”
may seem a little “Out there” for the general populous, but could be a big hit with us Display Newbs…
