I’m on holiday, which means soldering my latest module designs.
Here’s my version of Moritz Klein’s S&H + Noise module in Kosmo format, with some modding:
Switch to toggle the internal clock on and off
Manual trigger button (which also stops the internal or external clock if kept pressed down)
Internal clock made available as an output jack
Higher gain for the Blue Noise output (on par with white and pink levels)
Increased internal clock frequency range
Increased slew rate range
To my initial disappointment, the Blue noise output was dead.
At first I though I used some wrong resistor value, but luckily I didn’t have to rework any solder to solve that. See pictures.
I plan to design a long PCB that goes inside the rack to do normaling. The objective is to have a semi-modular synth when all my planned modules are ready. The extra headers on each of my modules just expose the inputs and outpus on the back, making them ready for connection with the “normaling” PCB in the future.
In mine I also plan to find a way to switch the “semimodularity” on and off somehow. I want the convenience of a tweakable bread-and-butter monosynth (with stereo signal path, mind you ) but also the hability to start from a blank slate for more crazy patches.
