If you intend to populate both U3 and U4, you may be up to an unpleasant surprise…
Per pcbnew’s DRC with standard footprints, these DIP packages
have overlapping courtyards. Pad separation center to center between #4 on top and #1 on bottom is a hair under 0.125".
cool !
mine IC socket type was more small on the plastic side
when i put an ic inside, it overflows slightly on each sides.
Lucky this time
(20…)
This looks rather large. What are its dimensions?
100mm x 200mm. The active BusBoard is also the same size.
Today, I got some new boards, A multimode filter I have been working on for a bit, and some purple V2 boards for my VC ADSR.
A couple of my previous designs have been in my case and working well unaltered, so I am hoping to get these written up and published in the next couple of weeks, but first I have to finish porting my VCV plugins to V2
Looks awesome! I’ve been looking for a multimode filter with voltage-controlled resonance. May I ask, what is the filter topology/core of this design?
I had some ideas from a software filter that I have been repurposing over the years. Electronic wise it is a 4 pole ladder filter based on the AS3320, with the 4 poles tapped and summed to give various modes. I wanted to not use the default resonance as I wanted more character, so I used an LM13700 and some non-linear distortion switchable between symmetrical and asymmetric. As this is negative feedback for the resonance the filter response tends to zero at dc, so I have added some of the original signal back into the feedback path. Oh, I nearly forgot the first pole is switchable by an octave, an idea I got when studying the 303 filter design, although this sounds nothing like a 303 diode ladder.
I shall post some audio when I finish the build
Please do, I’m very curious! Sounds delicious
LoL… looks like we had the same idea:
And after a long time I decided to buy a high quality DMM:
First impression: very fast and very accurate
The DMM looks very nice, is this just for Diy synths, or for professional use?
Its for DIY, not only synths, but also a lot of other electronic areas. I have 2 cheap Uni-T DMMs on my bench, but they have only 3.5 digits, can show values up to 4000, that means for example to measure voltages above 4V it can only shows 2 digits after the decimal point, or in other words in 10mv steps. This is very inaccurate to calibrate CVs. The Rigol can display values up to 240000 counts, and has a very low error.
More kits came in the mail yesterday and today:
Fred’s Lab Zekit - interesting as it uses some transistor optocouplers for CV control.
Now that I’ve got more than one synth I need some way to sequence them, so I got some boards and components to build this midithru-x2 from midisizer:
Hope to get building on the weekend!
Another JLC order came in!
Included the BMC040 dual logic CV mod boards:
As well as these little Fresnel lens quad vactrols:
Fits together neatly:
Tried them out with a few different colour LEDs, must say they look pretty badass:
I ordered a few different types of photoresistors, will do some testing in the coming days.
These LEDs look awsome, cant wait to see them used in a module. You may find some of us asking if we can use the design and how to fabricate them, or if you are selling any.
