Buffered Mult BOM:
16x Kosmo-style (5pin stereo) jacks
2x12mm m3 stand-off’s (optional spacer support)
6x trim pots, 2k preferred, 10k works just a little sensitive when you adjust each output
2x 1N5817 schottkey @power supply or just use jumper cable or 10R resistor if you don’t have.
2x male/female 2.54 pinheaders, each 1x10
1x eurorack style power 2x5IDC socket
2x TL074
2x 22uF polarized caps
6x 10pf ceramic caps
2x 6pf ceramic caps
4x 0.1uF ceramic cap
RESISTORS:
6x 12k
6x 300R
12x 51k
4x 100k
Build notes:
Each of the buffered outs has its own trim pot to match to each other. Use a known voltage source and plug it into the first input. Adjust the trimmers until the 3 outputs match the input voltage. Repeat for input 2.
Build as expected. all components silkscreens are correct. However, the trim pot silkscreens are mislabeled. Pretty easy to figure out once it’s built and you are adjusting the channel voltages.
