A thread for custom or just useful KiCad footprints and models for peoples designing PCBs.
I’d like to start by asking @lookmumnocomputer about the footprint for the jack sockets used in the 1222 VCO PCB.
Where did you get it? Is it in the standard library that comes with KiCad? If so, which part is it?
If you created the footrint yourself, can you post it here?
If if was from a library you found online, can you point us to it?
FYI to use the footprint that Sam provided above, create a folder called e.g. LMNC.pretty and copy the “Jack_6.5mm LMNC.kicad_mod” file in it then use the Preference->Manage Footprint Libraries to add that directory/library to your project library list (or globally).
Just to be on the safe side I replaced the space in the filename with an underscore, but it is not necessary.
Edit: The footprint can be used with the AudioJack2_Ground_Switch schematic symbol from the Connector library.
max ok it is on! I will waiver the fact that its on a computer for a livestream of course haha. any aspect of it in particular? I mean maybe the next time Im working on putting a module onto kicad I could do it, its rather time consuming and I do it in rather dotted sections but yeah maybe worth a go! keep an eye out for them
Oh hell yeah, I would love a crash course in KiCAD. Maybe something for the seriousish channel in parts, building a module from schematic to panel if you had the time!
Anything you have on the roster would be instructive, and I think everyone on the board would agree it would be the shizzle! If the ADSR or the 2xVCA are already laid out then the mixer or something-whichever needs to get done.
I tai nk both of those are a yes. they look like they are the same fit. and I guess some people have used those on my other circuit boards. on those footprints
