I’m not sure if I’ll bother making a panel for this one or not. If you split a clean and fuzzy signal and then mixed the fuzz back in, it might be useful for making claps and other preclusive sounds; if you don’t have a dozen ways to do that already.
Over all I’m a lot more excited for the Safety Valve’s official PCB release.
If you pressed me to give it a description I would describe it more as a “reactive white noise generator”
Don’t know if that’s ever actually been a thing, but that’s what my prototype seems like. You feed it a signal and it outputs noise that changes and reacts to the signal but it’s still basically noise.
I mean… the fact that the power supply varies with the signal undoubtedly makes a big contribution to the effect which you wouldn’t get with an active fuzz. But then, if you like the effect but not the signal level, there’s no rule saying you couldn’t build this and an active gain stage into the same module. Maybe even add a wet/dry pot.
I built this yesterday and the result did not seem perfect to me.
Maybe some mistakes. I checked the stripboard and changed a few things.
The 3.3K resistor was directly at GND while it normally goes through 330 before going to GND. And also some changes with the order of other resistance.
After test it works much better, good output level, more distortion, but the pot no longer acted. I changed one of his connection and his value and now I like it.
other test to do.
After others test, it’s ok with snare but not with hit, ok with Saw but not with Square,it’s passive circuit so really depending of the input level signal.
I may still do a second one to make a Dual module in a 5 cm.
Personally since I took it apart to get the parts, really not what I was looking for, and rather oriented myself towards a Rat and a Monotropa for the next case.
