You’re right , I guess it is a mix.
Funny enough , the triple spashback is the only one I didn’t buy. I already had a Stasis leak .
This year has been so darn crazy though, I’m just getting around to building now.
I keep seeing the FC PSU can deliver 500mA at the +/-12V rail. Does this mean it can deliver a combined total of 500mA, or does it mean the +12V rail can deliver 500mA and the -12V can deliver an additional 500mA?
500mA one each side (more carracters…)
Thanks, it looks like I can get away with just buying one then… for now
(it depends on the modules of course) but one for approx 8/10/12 modules max
Hey, could I use a 500mA powerd adapter instead of a 1A?
More amps on your adapter = more modules you can power off one power supply. In the US you can get a 2 amp. https://www.amazon.com/gp/product/B00R5CEDRM/ref=ox_sc_act_title_1?smid=A3O3SSGGJLKX15&psc=1
would I be able to power three modules with 500mA?
Yes.
I’d say so.
As you add modules. Up the wattage.
Edit: up the amps for clarity
id recommend at least 1.5 amps
well the thing is I need to be able to power three modules by the 31st. and the only power adapter I can get in that time is 500mA, later i’ll probably get another one.
yes 500mA for 3 modules that’s ok
I am new to all of this, and not building anything at the moment. But i was curious, using the frequency central supply and the 1500ma walmart, how many modules can you run? I am asking because i wanted to decide when it comes time to build to build 1 or 2 from the beginning.
Welcome to the forum ![]()
that depend of the consumption of each module
look here some numbers
you can counted near 50mA for each module
on the FC website :
" FC Power works from a 12V/1000mA AC wallwart and provides ~500mA at +/-12V, ~100mA at 5V (optional)."
so near of 10 modules for each FC power supply (except if this is 10 Safety Valve ahah )
Hi I’m new, sorry if this is a rehash but where can I buy the FC powerboard pcb’s? I’m in Australia.
Otherwise I’ll get some printed if I can find the gerbers. Cheers.
for a gerber one maybe here
surly a thread about it in the forum …
And if you want it with an additional bus board then you can use my version.
the link don’t work for me
Try now?
Got the gerber thanks bro. Now to source parts!
