so im starting this topic as I get a lot of questions regarding power supplies, and there are a heck of a lot of options!
the great thing is with this format is the power supply is the same as eurorack. so with that in mind. you can use the options open to eurorack. I guess it limits out things like the 4ms power as that has a eurorack power input module. but there are lots of options!
the go to for me is the mfos style wall wart power supply and I always suggest either the wall wart one by mfos of a very similar one by Frequency central the power diy pcb. these require a hefty AC power brick. But its what I have been rolling with for years.
another option is using a PC power supply I know people have had success with that!
currently I dont have a solution available. but im trying out a few different options and seeing what they are like.
after some research i found the befaco excalibus. its a hefty power bus and to be honest compared to other options it isn’t a bad price! I have ordered one to try with a whole kosmo synth voice and ill do a video with how I get on with it! it uses the same dc to bipolar brick as their jump skiff. but the excalibus is. well at least I think a relatively cheap option. Still quite a chunk more than the wall wart option which overall will set you back about 50 quid after buying the plug and the rest of the components. anyway I will relay back with my findings!
anyone else have any suggestions?
) on a Kosmo format panel
, It’s not cheap but it is a quality build and noiseless
