No bother. Let us know if you need any help with it.
New guy here with yet ANOTHER question! I hate asking questions, but I’m truly stuck and don’t know where to go from here. I really do appreciate all of you guys! I’ve only been on the forum for about 2 weeks but I literally read and search here daily!
Alright - I had my power supply working great earlier! I went to unplug the ribbon cable and must have jostled something around. I saw a spark and then the +5v and +12v LEDs went out. I suspect that some pins on the unshrouded header must have touched each other? I replaced the unshrouded header with a box header and the LEDs came back on. However, when I measured with my multimeter, I measured -12v, +5v, and +15v. I replaced the voltage regular on the +15v side just to be safe, and I’m still measuring +15v. When plugging the power supply into the module (VCO 1222), the +5v and +12v LEDs go off, and the module does not turn on. Could I have potentially damaged a component on the module PCB in the process? What else should I check on the power supply PCB? It was working great earlier before I screwed it up ![]()
Hi All,
I’m hoping someone can help confirm my understanding. I have two FC Microbus connected to one power supply in parallel (picture for reference). They are currently connected to a 1000mA 12V AC wallwart which works fine but I am outgrowing it. I want to use a 2000mA 12V AC wallwart instead. Is ok? I emailed Frequency Central earlier this week and waiting to hear back. Thanks!
These use 7812/7912 regulators; the datasheet says they can supply 1.5 A but more like 1.0 A is probably more realistic. That’s each and between the two boards there are four regulators, so you can imagine them being good up to a total of 4.0 A. Ideally.
The web page Microbus – Frequency Central says a 1000 mA wall wart but that’s for a single PSU, so 2000 mA feeding two PSUs should be okay.
Same issue as some others here - I had the right voltages in the right places, but no LEDs were lit. I had the LEDs reversed. Fixed that and all looks good now.
My motto: never blindly follow the silk screen. Always keep the schematic near. Especially when caps are involved.
yep, because unlike baseball caps, some matter which way they go round lol.
Oh there’s a difference; not judging:)
