Hey everyone,
This is to detail what you need to build the Microbus. The build doc’s BOM is nearly identical to what i will provide, and @lookmumnocomputer has a wonderful build video that covers the process. There is also a builders livestream as well. The video shows the smaller version, but its basically the same thing, only a bit more to do.
Sam’s Video:
Builder Livestream:
https://www.patreon.com/posts/fc-power-diy-27556693
Here is the build doc from the frequency central website:
I bought the PCB here (US based):
https://synthcube.com/cart/frequency-central-microbus
$16.00
£12.29
Quantity: 1
OR
You can also buy from the frequency central site itself:
https://frequencycentral.co.uk/product/microbus
$15.62
£12
Quantity: 1
Bill of Materials:
1K OHM 1/4W 1% METAL FILM RESISTOR ROYAL OHM TOP QUALITY
https://www.taydaelectronics.com/resistors/1-4w-metal-film-resistors/10-x-resistor-1k-ohm-1-4w-1-metal-film-pkg-of-10.html
$0.012
£0.0092
Quantity: 3
0.036
100NF 0.1UF 100V 5% POLYESTER FILM BOX TYPE CAPACITOR
https://www.taydaelectronics.com/0-1uf-100v-5-polyester-film-box-type-capacitor.html
$0.10
£0.077
Quantity: 2
0.20
100UF 35V 105C RADIAL ELECTROLYTIC CAPACITOR 6X11MM
https://www.taydaelectronics.com/100uf-35v-105c-radial-electrolytic-capacitor-6x11mm.html
$0.03
£0.023
Quantity: 3
0.09
4700UF 25V 105C RADIAL ELECTROLYTIC CAPACITOR 16X26MM
https://www.taydaelectronics.com/4700uf-25v-105c-radial-electrolytic-capacitor-16x26mm.html
$0.60
£0.46
Quantity: 6
3.6
L7812CV LM7812 L7812 7812 VOLTAGE REGULATOR IC + 12V 1.5A
https://www.taydaelectronics.com/l7812cv-lm7812-l7812-voltage-regulator-ic-12v-1-5a.html
$0.23
£0.18
Quantity: 1
L7912CV LM7912 L7912 7912 VOLTAGE REGULATOR IC -12V 1.5A
https://www.taydaelectronics.com/l7912cv-lm7912-l7912-7912-voltage-regulator-ic-12v-1-5a.html
$0.24
£0.18
Quantity: 1
L78L05ACZ L78L05 78L05 +5 VOLTS 100MA VOLTAGE REGULATOR IC
https://www.taydaelectronics.com/l78l05acz-l78l05-78l05-5-volts-100ma-voltage-regulator-ic.html
$0.09
£0.069
Quantity: 1
1N4004 DIODE 1A 400V
https://www.taydaelectronics.com/1n4004-diode-1a-400v.html
$0.02
£0.015
Quantity: 6
0.12
LED 3MM RED
https://www.taydaelectronics.com/led-3mm-red.html
$0.02
£0.015
Quantity: 3
0.06
HEATSINK TO-220 4 FINS ALUMINIUM
https://www.taydaelectronics.com/heatsink-to-220-4-fins-aluminium.html
$0.24
£0.18
Quantity: 2
0.48
DC POWER JACK 2.1MM BARREL-TYPE PCB MOUNT
https://www.taydaelectronics.com/hardware/dc-power/dc-power-jack-2-1mm-barrel-type-pcb-mount.html
$0.16
£0.12
Quantity: 1
16 PIN BOX HEADER CONNECTOR 2.54MM 2*8PIN
https://www.taydaelectronics.com/connectors-sockets/box-header-connectors/16-pin-box-header-connector-2-54mm.html
$0.18
£0.14
Quantity: 8
1.44
I use these to lift the panel from my table, but you need to at least buy 2 screws to mount the heatsinks.
What you do is screw the standoff pins into the holes of the PCB, than you can use washers and nuts to hold in place. The screws in the pic are longer than I am recommending here.
BRASS STANDOFF SPACER GOLDEN SCREW HEX MALE M3X30MM
https://www.taydaelectronics.com/brass-standoff-spacer-screw-hex-male-m3x30mm-golden.html
$0.27
£0.21
Quantity: 4 / 6
1.62
M3 STAINLESS STEEL SCREW CROSS ROUND HEAD M3X10MM
https://www.taydaelectronics.com/hardware/nuts-washers-screws-spacers-and-more/screws/m3-stainless-steel-screw-cross-round-head-m3x10mm.html
$0.02
£0.015
Quantity: 6 / 8 ( 2 are for heat sink )
0.16
NUT 3MM FOR SCREW M3
https://www.taydaelectronics.com/nut-3mm-for-screw-m3.html
$0.02
£0.015
Quantity: 4 / 6
0.12
WASHER 3.3MM FOR SCREW M3
https://www.taydaelectronics.com/washer-3-3mm-for-screw-m3.html
$0.02
£0.015
Quantity: 8
0.16
Ribbon Cable Components
Ribbon:
16 CONDUCTOR AWG 28 FLAT RIBBON CABLE 1FT (30CM)
https://www.taydaelectronics.com/hardware/cable-wire/awg-28-16-conductor-flat-ribbon-cable-1ft-30cm.html
$0.33
£0.25
Quantity: I got like a few feet. Whatever is good for you.
$3.3 for 10ft
Socket connector:
Get from Tayda if you dont need a bunch, otherwise amazon has good prices.
IDC SOCKET CONNECTOR 2.54MM 2*8 PIN DOUBLE CONTACT
https://www.taydaelectronics.com/connectors-sockets/box-header-connectors/idc-socket-connector-2-54mm-2-8-pin.html
$0.30
£0.23
Quantity: As many as needed, consider getting the amazon link if grabbing loads.
$4.8 for 16, enough to make cables for each slot. I just got from the amazon link so i would have a lot of them.
Antrader 50 x FC-16P 16Pin IDC Socket Connector Female 2.54mm Pitch Plug Header Connector Dual Row
https://www.amazon.com/gp/product/B07DVW1BS9
$8.99, $0.18 each
£6.91, £0.14 each
Quantity: 50 (Comes this way)
AC Walwarts:
They recommend 1000mA 12VAC Wallwart, it MUST be AC / AC! I can only advise for US plugs.
This is what I use (US plugs keep in mind):
Jameco Reliapro ADU120150E1012 AC to AC Wall Adapter Transformer 12V @ 1500 mA Straight 2.1 mm Female Plug, Black
https://www.amazon.com/gp/product/B00B88621O
$14.82
This is the link that Frequency Central links to:
1000ma(1a) 12v 12VA AC/AC (AC Output) Power Adaptor
https://www.poweradaptorsuk.co.uk/1000ma_12v_AC_AC_Power_Adaptor_p/ta100012ac.htm
£8.45
