Hello! Glad to be apart of the community! Any help at all would be appreciated.
I started with this project because i wanted to be able to plug my headphones into my synth and hear sound in both ears god dangit. While i believe there may have been easier ways of getting what i wanted, I really wanted to get hands on experience with KiCad and the PCB designing process. However, after getting the PCB fabricated and populating the boards it became apparent i may have made some assumptions i shouldn’t have or simply don’t know as much as i need to. I would also have liked to share the gerber file but am not entirely sure how to best do that.
On pg2 of the Schematic i listed some of my assumptions but will list here as well:
Sliding VB was changed to a A100k knob VB
I didn’t know how to get The 2 gang Variable resistors
to have a proper symbol with pins 4,5,6. instead of 1,2,3 a second time. If the Gangs are in front(closer to you) pin 4 would be in front of pin 1 far left. .
RV5, RV6, RV7, RV8, RV9 are all these 2 gang VBs.
The 2 gang variable resistor i was using: RK09L12D0A1W -
All Grounds are connected to the ground pour which seemed fine in this case based on the research i did.
