I wanted a buffered multiple with three outputs, so I put together this one, which combines the design of Analog Output Buffered Multiples (output resistor in the loop) and the +/- voltage indicator from Skulls & Circuits Buffered Multiple. Unless @analogoutput tells me that there is something wrong in combining the resistor in the loop design with the LED indicator of that “spare” op amp, I’ll label this as verified as I’ve built one and works fine as far as I can see.
