something wrong with my design; my grounds are not ground, if that makes sense…cant spot a problem…maybe the 12v in at the expression cv?
PS im aware im using the S pins instead of T on the jack symbols…it gets corrected when the footprint is placed…silly thing i noticed ive been doing and need to fix
By the way, you probably want pin 1, not pin 3, of your pots to connect to ground.
Something’s wonky with the jacks, you’ve already indicated that but it looks even wonkier. T is supposed to be tip and S is supposed to be sleeve and S is where ground should connect. Your jacks may have a separate G terminal in which case you need to tie G to S. But for the expression pedal jack you should be connecting input to T, output to R, ground to S (and to G if there is one).
OK, that’s flipped so we’re looking at the pins from underneath, right? So what’s labeled S is actually T and what’s labeled G is actually S. 5 is Tn, 3 is R, 4 is Rn. For the pedal input should connect to what’s labeled S (actually T), output connects to 3 ( R), and ground to what’s labeled G (actually S). On your schematic you’re using pins labeled T (on the pedal jack) and Sn (on the input) neither of which appears on the footprint so I don’t know how KiCad is letting you do that.
These are the jack symbols I’ve used
and for all of them I’ve used this footprint (flipped to see from underside)
basically that was the first footprint i made and i picked the names of pins to match the wrong symbol…the G and the S are S and T in reality…i must have messed something up electronically at the expression jack…looks different than your setup
You have input connected to R and output connected to T on the expression pedal jack, but that may be okay, some pedals are wired like that (mine is switch selectable). NM, looking at it upside down
it doesnt burn up or smoke but it doesnt work either lol. plugging something in gives me alot of noise/feedback…touching the cable sleeve cuts out noise.
meter between rails is 24v…good.
meter between jack grounds and either rail gives zero volts…
You’ve measured connectivity between your sleeve terminal and the ground power pins? Have you checked for islands in your ground plane? (But they would show in KiCad as unrouted connections.)
Going to look at it again with fresh eyes today after work. If I can’t find something else, I’ll fix up the jack symbol horror show and rewire. Both circuits are so simple it’s gotta be something silly
Alright, so I figured out what happened. The file i shared yesterday was the primary pcbnew instance. When I printed boards I separated the files and for some reason the copper pours aren’t connected to ground on the copied over version. Must have updated something when I went to generate the gerbers…so basically nothing was grounded except the power header
